engine running lean
xtorm
1,590
49
engine is pinging when the weather is hot, all smooth when it's not.
took the sparkplugs out and realized the mixtures are too lean
what can i do to overcome this? fuel regulator? pump? bigger injectors? just the simplest and cheapest way to do it.
lonelylilpig
832
33
Mayb your fuel pressure is insufficient. Try check the fuel pressure and c how much it achieve. Or mayb your injectors is dirty or sumthing.
Btw, wat car u driving bro ?
contreasjun27
9,000 RPM
9,045
25
subang
are you sure is running lean due to the weather is hot?
basically if your engine is running lean no matter is in hot or cold weather still the same dude
xtorm
1,590
49
old suzuki swift. erm don have meter to check it out. how much to clean the injectors?
erm...i confirm its running lean after checking the sparkplugs, get what i mean?:driver:
khoyos
2,633
156
5,163
Shah Alam
bro, i have seen a few cases, engine running nicely on ron97, but after using ron95, plug jadi putih.
well to be specific in solving the thread starter's problem, better plug in wideband o2 sensor, check which point of rpm range that is running lean. if its constantly lean all across rpm range, then a fuel regulator would do. if there are specific areas of the rpm range, then u need to tune on that specific range, perhaps using s-afc or other fuel controllers.
xtremeleo
3,247
464
5,183
both of my cars changed to ron95 full time, but no problem so far. maybe the case u saw were coincidencial kot, anybody got dis problem tak?
as a general, the TS problem can just be solved wit a FPR, increase it a lil bit jer, IF ur fuel pump is still in good condition ler..
xtorm
1,590
49
try using ron97?
initially i tot that too, but no help....
just tried the original regulator without the vacum hose(hence running full pressures), things improve alot, but still abit around 3k++, but gone once i press the pedal.
anyway, something i notice, i reseted the ecu after the notice the ping, it was ok then, 1st tank was esso, no issue, then after i put in petronas it started to ping, changing to shell 97 didnt help, haven got a chance to try esso yet. need to try out tis to confirm
i have read that advancing the intake, retarding the exhaust gives less overlap for better low end power and vice versa gives more overlap which is good for high end power in expense of low end
what about advancing intake and advancing exhaust? or retarding intake and retarding exhaust? what kind of changes can we expect?
reason i asked is my kelisa has twin cam but behaves like a sohc coz got only one cam gear running both cams so cant adjust intake and exhaust independently
also, what...
