advise on vr4 and gsr
scoot3331
98
all the masters of turbo....bro which engine is better ,more reliable...and more powerfulll....and i also want to lnow bout the mivec turbo..does it overtake all the bth engine mentioned aboved...performance and reliability wise...iam a newbie...hehehehe..thanks
jinkl
4,623
376
3,183
all turbo engines are reliable when its stock :P
only when ur hand medles with it , then u head towards the other side of the field :P
with a gsr and some minor mods u r looking at
200-220whp
stock vr4rs around 260whp
mivec turbo combination is
gsr + mivec head which will give u extra 20hp maybe
in the sense of making higher power easier , of cos vr4 are stronger
and has higher cc engine
gsr's are more fragile
GT_AUTO
3,501
71
1,648
K.Trg
www.facebook.com
vr-4 is the better engine compare to gsr in stock.powerful n reliable.
the potential for bigger hp is also falls on vr-4.
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
gsr is 1.8L rite??... vr4 is 2.0L??....
yeap, vr4 block is much stronger... some even rojak evo head with vr4 block to achieve more horsepower from higher boost...
another question, which is better, evo or vr4??...
karl5511
1,014
yes, me also interested to know which one is better...
Evo3 or VR4...
boyzone
2,669
5,148
legal on the road with Wira chasis = GSR.
legal on the road with Perdana chasis = EVO.
Both engines are reliable.
Performance vise is base on how much $$$ u burn.
of coz, base on stock to stock .. 2.0 is stronger than 1.8 engine as u can gain more torque.
karl5511
1,014
What about Proton Putra?
Is it legal to put in Evo3?
mag9556
2,770
43
1,648
101% nope... :biggrin: If can also a lot $$$ need to kaw tim the JPJ and can not confirm that can renew roadtax or not...
boyzone
2,669
5,148
u can gain good power to weight ratio by put in GSR in Putra chasis.
jinkl
4,623
376
3,183
so far as i can see
most of the gsr owners regret having them
i mean the ones that really love modding will know its limitations and the upgradability
want me to do the calculations ?
ok here it goes
gsr halfcut RM6500-6800
evo halfcut RM6500-7000
gsr 1.8cc
4wd gearbox
390cc injectors
td04 turbo
180hp stock
tissue box puny intercooler
single pot brakes
1.8cc
evo
4wd gb 1st n 2nd gear twin synch , close ratio
510cc injectors
bigger throthle body
td05 16g
260-270hp stock
big intercooler
2.0cc
twin pot brakes
do the calculations urself , which one is more worthit ?
for a gsr to upgrade to 510cc injectors , evo airflow , td05
evo ecu ,bigger intercooler , twinpot brakes , it will cost u close to 2k-2.5k
for me the evo is more worth the money
aproval ? haha
rather than paying the extra's on the gsr's upgrades
i might as well buy a 4g67block which is 1.8 block
and put all the 4g63 stuff into it , it will produce power just same
as the evo , further more there are still 2.3 stroker kits and lot of stuff
awaiting u
karl5511 said:
Hello Bro jinkL,
Sorry to bother u this morning...:biggrin:
Something want to ask.
Actually i'm planning to put evo3 engine (4G67 I think) on my Putra. I was told it was the best amongst Evo1-3, GSR, VR4 which can produce 260hp in stock condition. Is it true?
May I know the h/cut price, workmanship price, and additional price (gasket, clutch) necessary? (agak agak one la).
And last ques, will it be approved?
My ride is Proton Putra.
Thanks.
as for ur pm , the best stock condition turbo and responsive beast
would be the evo3 , higher compression and has a bigger turbo spec compared to evo1 and 2. but it cant stand high horsepower , the conrods will stand up to 300-350hp maybe if u r lucky, but 350 aint it enuff for u ? ask urself first :) , but the vr4 block has been proven to hit 400whp on stock block , the limitation of purchasing a vr4 halfcut is that the ecu is old tech , the airflow is old tech , the turbo is smaller , the throthle body is smaller , the intercooler is smaller
karl5511
1,014
awaiting u
Errr...:hmmmm:
You mean, Evo3 engine with 1.8cc block?
scoot3331
98
guys thanks alot...u all damm power man...know alot bout turbos...if gt any ques summore i will fefer to u guys..thanks...
karl5511
1,014
Sorry to bother you all guys, newbie here...
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
Errr...:hmmmm:
yeap... i've seen saga with vr4 head with 4g67 block..... 4g67 block is 1.8L, so passing jpj is possible... but one thing i dun understand, after passing jpj, i heard the owner stick with 4g67 block... he claim that it is even better compare to vr4 block.... any sifoo can explain why??.... is it because 4g67 has shorter stroke, thus can rev up more easily??....:hmmmm:
jinkl
4,623
376
3,183
skywalker : nah , 67 and 63 have the same stroke only diffrent bore sizes
u only need to change its piston to make it a 1997cc engine :D
y he said that ? i guess because of the balance shaft removal which is common when they put in the 67 block , the next would be bcos he would have overhauled the engine
any other things, tell him , his mind is playing with him hahahha
karl5511
1,014
awaiting u
Puspakom will approve base on what? In term of what exactly?
mag9556
2,770
43
1,648
They will approved base on the "CC"...
not Puspakom but JPJ.. u have to send letter to apply with JPJ for increasing the cc of your car...:biggrin:
karl5511
1,014
better than u drive illegal car later..... hehehehehhee:biggrin:
So, if I put in 4G63 stuffs with 4G67 block can ar?
Errr, 4G63 & 4G67 is what actually?
I just know 4G91, 4G92 and 4G93 onli...:biggrin:
hi people
i am driving a tx3 1996
my car jerks when i step on the fuel pedal slowly or even when it's idling....the rpm would go down and up a little bit...this cause the car to shake even when it is not moving.
can anyone pin point the problem?i tried replacing the spark plug...ok for a few days( little jerk), plug cable, throttle body,,,,problem still persist?any idea what happen.?it happens when a/c in turned on and off
pls advise?
