how to turbo a carbie engine
SE86
299
474
1,563
any sifu can help me on this??i wan to turbo my toyota 4K engine..wat turbo can use and wat modifications need to be done..juz wan increse some extra power...
jo-e34
222
69
5,028
seremban
how much extra do you trully want?with the internals of your 4k there is not much u can do.....dude......:burnout: going above 0.3 bar for your engine would be dangerous......any ideas on what is your standard hp output?
fluffy?
214
like jo said..no point spending so much on ur carbie..
use 4k and swap in a 4gze!
rsdn
15
I agree that 4K has low hp around 60 to 65hp but swapping engine to 4AGE or 4AGZE is very expensive and illegal too(cos have to modify the engine mounting to fit)
So i just thought maybe stick with the 1.3cc engine and try to play around with. Even though it cant drift, maybe an extra power will be fun when u trying to overtake cars.
If anyone who is kind enough to share his or her knowledge on how to turbo charge or super charge on a 4K engine, i would be very glad. Thanks.
I have tried sourcing to rollaclub website for this info but they use the brand and items sold in their country.
SE86
299
474
1,563
hey bro..standard engine also can drift d la...juz need to make the axle ratio ...in rainy days it will just sweep of the road wan...must careful wan...
klgauto
Over 10,000 RPM!
12,199
10
Klang Sentral
www.klgauto.zoomshare.com
the intake & exhaust port is at same side for 4k engine , so if you turbo charge it , the intake manifold will run very hot , because of the exhaust port is just below it .
it can be done but it will cost you almost as same as a ae86 halfcut prices, so it is worth or not ???
caleb_5375
1,293
14
i think u better swap engine better...a gud mech will kao tim for u and sure pass JPJ and even puspakom no problems lah..undertable a bit lor ..hehe..
coz if u turbo ur engine now u cna't get much and it is total waste money and the effort....sumore waste petrol sob sob........
Hi Guys,
I've recently decided i'm not happy with the power my Evo 8 MR is making, its currently running about 320 at the wheels (although there is an issue with a lazy tappet causing it to only run at 280). I'm running high cams, straight through exhaust, blow off valve etc... I want to squeeze some more power out of the car with simple and cheap (but effective) mods. I don't want to go spending alot of money on the car and i can't run higher boost (1.8) as this has been done before and...
