change sport spring
sky9002
15
If i change sport spring front part only will how?? more shake or will not comfortable??
sky9002
15
for AXXeLL,boyzone,GT_AUTO opinion is better front and rear use sport spring?? but i dont know why this sport spring i bought high degree like original??
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
yes, better go for front n rear if u wanna lower ur car... if not, under heavy braking into a turn, the rear will be tail happy....
choose urself, to look good or to be alive...
boyzone
2,669
5,148
For those branded sport spring, actually they have different different spring rate and spring height to let people select.
How height is ur car after install?
Btw, what car u are driving?
strangex2
238
I just changed my front springs to APM performax. Only the front springs, the rest still stock. Riding on 14", don't wanna change the rear springs coz have to grind, so malas la. Now test test all types of conditions and see if got any problems or not. Front 1 finger gap, rear (stock stuff) 2 fingers.
So far so good, the car feels nicer to drive, stiffer and more 'solid feel'. My car is Kancil only, so won't be too tail happy. Anyway, I don't whack corners so ganas.
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
what do u mean by "have to grind" strange???do u need to do that to install
sport spring to ur kancil meh?
sky9002
15
after install my car height is four finger can put in.. can say same with original
my car is accord 1986 year SA6Y
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
dun have lar.... sport springs usually dont have spring rate for u to choose... u jz tell them what car u driving and they give u a set of springs... thats it...
unless u going for coilovers, spring rate can be choosen if u buy from factory...
strangex2
238
I am running on 14" rims with 165/55 tyres. If put sport springs on the rear, the tyres will hit the inner part of the body, thus have to grind out a section of it so that the top of the tyre can hide behind the body. Ketuk also can lah, but that wan tend to lead to rusting.
Standard 12" put sport springs on rear no problem wan.
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
ooooooo......umean the tyre will foul ur rear fender is it.i c...even iswara
have to roll the fender to make clearance for a bigger wheel n tyre.
strangex2
238
Oh, you orang call it 'roll the fender' eh? My friends all 'grind' it, chop the section off.
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
roll, fold, grind, chop, knock... all relate to the same thing lar... make the arch a lil bigger so more clearance for the tyre...
but ppl usualy do folding/knocking... rolling needs a tool, which can be found in only certain tyre shop, which is not cheap...
grind and chop is abit too extreme adi...
guys, need help.
My car is 9gen altis, 2003,
I was driving for almost 2 hr, then smell some short circuit burning smell inside the cabin.
park the car at the road side , then i realized headlight cannot be turned off.
i quickly disconnect the battery to prevent further damage to my car.
it didnt gv any sign prior to the burning smell. and the smell came from the steering wheel itself, on top of the airbag area
anyone can guide me here?
