Kelisa's Timing Belt's Life
Jul 29, 2007
2
How abt a car's timing belt's life??
my kelisa is going to 70,000km...should i change my timing belt at this time??
and the how much of changing the belt probably???
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
since ur car is already reaching 70k,u can change it for safety precaution.
if i'm not mistaken,the ori will last up to 80k.about parts n labor,i'm not
sure.
kelisa6009
Over 10,000 RPM!
17,144
40
Penang Kia
better get it change...i change at 60,000km...but the condition of the timing belt is still ok...
but for precaution better change...u never know if the timing belt got defect
ALTAIR SR20
31
JALIL HEIGHT
i changed my kelisa timing belt at 100002.the condition of that timing belt is still ok hehe but playsafe and change it early.my fren spectra broke its timing belt at 81000km and all the engine blown,have to change all from hulfcut.
jaydee123
145
Fortunately for all, all new cars now use timing chain which can last for more than 250,000 km. Just need to check every 50,0000KM after that. But the water pump might leak before the timing chain cause problems. :)
nonameNo
45
based on manual, it stated the belt can last for 100,000km. just to be safe pre-caution, change it around 80,000km will do coz you have to consider the time taken during jam, waiting and idling.
mag9556
2,770
43
1,648
Actually the factory is correct as 100,000 km is include u start engine without moving time...
If like to play pick every day, it is better change it at 50,000 km as I have fren that change 2 engine coz of timing belt and he just drive 55,000 km onli timing belt say bye bye and the engine whom fall in love with the timing belt also say bye bye...
Good Luck...
Dec 25, 2012
Good Luck...
that means all the engineers are stupid when they released the spec >.<. when they sell you the car they only expect you to run the car in the garage and not driving the road....
Supra_Fanatics
20,685
3,998
Recommended to change between 80 - 90K km I bought my kelisa 2nd hand and at that time mileage is already 89000KM+. So, I got it change after a month when is around 90000KM+. Since is a 2nd hand car, I change it for better precaution judging by the brake pads used by previous owner, was almost botak. Too dangerous to use & will damage my brake disc if use further.
Kinda neglecting his own safety.
After changing, recommended to change timing belt at 80K KM by my mech...
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
If not mistaken, based on user manual... should change at 70k km mark
...and as per bro Danz said, do change your water pump as well
*I might not owned a kelisa but my kancil's (850 EZi model) original engine was the 850cc twin cam injected engine.. same as kelisa's 850cc model (one with black bumper)*
DanzEterna
15,910
3,371
www.primeperdanaclub.com
but some brands like gates can lasts up to 100k kms with warranty.....
it also depends on your driving style.....turbo cars running with normal belts have to change 50-60k kms, those
running on kevlar belts can lasts up to 80-90k kms.
Supra_Fanatics
20,685
3,998
Mine only 6 months warranty I think...
amrancharger
779
96
i owned a perodua viva and i opt to buy a good quality timing belts.
the shop said its original daihatsu and cost rm175.rm50 more expensive then GATES.
and i chose to change my belt every 80k km.
hi.. juz wanna ask any bros out there that would like 2 share their oppinion.. Ive juz installed my car a new grill.. i dunno wats the exact model name.. but it is veri common.. juz a grill dat is hollow n hav d netting..
my concern is, is the hood safe from being opened??? yes i knoe u must pull the 'hood opener' from the inside, but since it is hollow compare 2 d standard wira grill, can it juz be kopak by the thieves.. since the netting looks so vulnerable...
sori if i ask a silly...
