G/B Mivec/GSR Final/Close HP/WHP,FHP..ratio helpz
bertdeen30
971
www.friendster.com
i want to know .
im using a GSR block running Mivec head with mivec activate.
so which gearbox and fly wheel is the best
GSR FLYWHEEL OR MIVEC FLYWHEEL THE BEST IF REACH 400 ABOVE HORSEPOWER.
NEED ANY MODIFY OR LIGHTEN ON GSR OR MIVEC FLYWHEEL OPR LANCER MX MR ?
WHICH GEARBOX IS THE BEST
TIPTRONIC GEARBOX FROM MIVEC ? IS THAT TRUE ? I HEARD PPL SAID ACTUALLY IS A TIPTRONIC GEARBOX FROM LANCER MX MR OR MR MX.
TIPTRONIC FROM LANCER
MANUAL / AUTO MIVEC GEARBOX ... FULL LOCK OR HALF LOCK LSD .
MANUAL OR AUTO 1.8 ORI GSR GEARBOX , 1.8 GSR RS , PUTRA , SGTI G/B
WHICH GEARBOX IS THE BEST OR ANY OTHER AFTERMARKET SHOP CAN DO BETTER GEARBOX BY MODDING THEM PLEASE LIST FOR ME .
ANYONE CAN HELP ME .. TQ FOR YOUR ANSWERING
jinkl
4,623
376
3,183
i want to know .
above 400hp is very very far for a Mivec 1.8 turbo to reach for
without forged internal the conrod would have snapped and broken
as for gearbox , as for mivec turbo cars , to rev high n long u need Mivec gearbox , and not the triptronic gearbox , auto gearbox has only 4 gears
gsr gearbox will have shorther pulls , mivec will have longer ones for higher revs
i doubt both gb's will last after 400hp. only gb that realiable above that hp would be the Evo's.
as for lsd , full lock is fulltime lsd , while semi only activates on acceleration n deacceleration. brands would be cusco , kaaz , adelia and such.
if the halfcut shop says they will give driveshaft cos this gearbox driveshaft diffrent, then its confirmed to be a Standard Mitsubishi LSD gearbox which will be one of the useless LSD unit out there hehe. i run on Adelia magic , seem very good so far
boyzone
2,669
5,148
errr.. GSR block with mivec head is it NA setting?
from ur question, seem like u are run with NA engine, of coz 400hp from this set up is very very far unless u go to turbo inside and stand alone ecu to fully boost up.
bertdeen30
971
www.friendster.com
yahoo..~ yes is GSR block with mivec so is 1.8 mivec turbo ., JINKL u forget me white color wide body eVO5 custm body wira , with u minum at the back of kelana jaya..im bertdeen la..~
looking forward to downgrade to GSR block = can plug oil cooler also turbo oil return ma
that why is gsr not 4g93p is 4g93t . i alredy got few contact of mivec turbo . specialist doing more than 400 over horsepower . so looking forward more and more . and detailing . thanks for both answering
jinkl
4,623
376
3,183
there are lot of ppl claim to do 400+ hp mivec turbo's , bt none of them come forward for the drag battles n events, so as far i can see, DYNO means nothing, ur quatermile says everything else. anyone can claim HP on dyno , dyno charts can be tweaked , there was a very funny story , a mivec and vtec , both modded , mivec had more hp on dyno , on the quatermile the mivec was left behind , haha
bertdeen30
971
www.friendster.com
what i have found 1.8 GSR conrod is longer than mivec ori 1.6 block .if using back of 1.6 block shorter conrod . faster respond like ferrari . with bigger piston is that work . or longer conrod on gsr block ?
may the horsepower cause clutch slipped , and wheel slip ?
or the best is like ppl said how to put the horsepower on the ground
as what people said with the lowest horsepower with theh highset torque ? faster respond like GTR-34 Skyline Tomei RB28 and JUN Lemonande Supra ?
low horsepower But crazy torque on track every single reV make then boost crazy~
jinkl
4,623
376
3,183
u got it wrong , u know y gsr conrod longer ? cos its 1.8
mivec is 1.6 thts y shorter , if u use mivec block n put bigger piston also u nt gonna get 1.8 , no way :)
bore & stoke = cc
mivec = 81.0 x 77.5
93t/93/93p = 81.0 x 89.0
of cos more hp the clutch will slip
hw to put hp on the ground , correct rim size , LSD , correct gb ratio , super good tyres
no la, lowest hp with highest torque who la told fastest response bro ,
got the wrong info la bro , lowest hp highest torque is 4X4 like Storm la
storm : 138ps at 3,500rpm, and 314Nm
evo : torque was 228 lb ft at 3000 rpm.
kRiminaLz
552
3,018
Docklands/SAlam
bertdeen 30,
sorry to say that ur a confused man rite now...
go n stick with ur 4g63t variant...
from other post, ive read that u r using a vr4...
y dont go for evo mods instead...
u r messing with reliability if ur planning to do a mivec turbo..
like what Jin sd, ur g/b and ur engine as well will be gone before it even reached that 400 mark..
for a 4g63t variant, it will cost less to get the desired 400hp than modifying a mivec turbo..
do a serious research 1st bro...
jinkl
4,623
376
3,183
hehe see sifu kriminalz already said :)
bert : if u finding hard to get it registered, opt for 4g67 block n solve ur problem
jinkl
4,623
376
3,183
lolx , vr4 is one of the strongest 4 cylinder engine n u throw it for a gsr, y bro ? kaka
DjRevo`
311
Ipoh Mali
ahaha jinkl im here dying to play 63t and he pulak downgrade to gsr. hahaha gsr not as a powerhouse 63t is.
bertdeen30
971
www.friendster.com
1997 Boxster
2006 Boxster S
NSX C30a~ haih. this all car is better than 4G63T . rather throw this damn car if all mitsushibi is junk . cause 4G63T is always only a 2.0cc 4 cyclinder ..
me not driving my car already 5 month~ no warm up also~
jinkl
4,623
376
3,183
1997 Boxster
2006 Boxster S
sure la bro , u nt yet see the potential of ur car, nt tuned n nothing done yet
u can alwiz go for 4g64 2.4block n get it stroked even higher hehehe
bertdeen30
971
www.friendster.com
2.4 on wira impossible lagi is 4969 not 4g64 hehe~ i already want to put all back to ori vr4 and everything internal mod back to evo then comfort drive only . dont want performance buy better car .
lavodo
159
bro bert.. u really got confused.. better do research 1st bro.. 4g64 = pajero petrol block.. 2.4 cc..
i think u really dont know vr4/ evo's potential..
maybe someday u'll see.. hehehe.. there a lot evo / vr4 owner with 4g64 block with 87/88mm forged piston.. with fine tuning achieved 500whp easilly.. of course with some others performant parts..
kRiminaLz
552
3,018
Docklands/SAlam
apart from that.... we smoke others pretty fawkin eazy..
well.. just do ur research bro..
downgrade is stoopid..
Guys anyone lost their White Wira Sedan lately? i saw a white wira few days ago, from federal highway exiting to SS18, the car was parking over there for few days ago, yesterday night when i was on my way back, i saw that Wira got no sport rims and spoilers anymore. so i assume its been stolen. anyone who lost theirs can go there and have a look. plate number not sure.
thankz
