Sports Springs - To raise the height
e1fnd
94
Guys, need your expertise... If I have a set of springs and its getting too low... can I heighten it back, Iheard you can put some rubber to make it higher, is this true?
dennisdreams
333
21
There is a type of 'accessories' use to prevent the spring to 'closed' up during the bounce cycle. It didn't help much on lifting the car though. Just give extra support for a short period of time. The best way is still used back your Original spring.
Lately i noticed a lot of car theft. So i would l like to share with you all an idea.
This is cheap and dam effective...
Did you all noticed that nowdays maxis,digi and etc all nowdays have Friend Finder function? where you just type "FIND HPNO" to finds wheres the location of your friend? instead finding your friend, why not find your car?
1. Get a cheap handphone (nokia 3310 is known for its powerful antenna)
2. Change the battery to a better one (ex: 800mah change to 2200mah, so no...
