Rocket Motorsports Valve Springs for B-series(made in usa)
Gen 1 Spring Specs:
- 95 lbs. on the seat and 265 lbs. at 12mm of lift.
- Can handle up to 13+ mm of lift when used with Gen1 retainers.
Gen2 Spring Specs:
- 55 lbs. on the seat and 180 lbs. at 12mm of lift.
- Can handle up to 14mm of lift when used with Gen2 retainers.
Gen1 and Gen2 Inner and Outer springs can be mixed and matched to attain different spring pressures.
Gen2 Titanium Retainers
- Made of 6AL4V titanium.
- Provides increased install height allows you to use higher lift cams
- Superior fitment provides more retainer to valve seal clearance and prevents spring binding
Rm1k!Pm me now fast fast fast!
Gen 1 Spring Specs:
Gen2 Spring Specs:
