Putra Auto Transmission To Manual...
roadster182
HI guys..
actually i'm going to change my car transmission to manual..
n n dont know how much it cost..
anyone can suggest me any wsyop n how much for the cost..
hopely u guys can help me with this matter
thx guys
mag9556
2,770
43
1,648
Nowdayz not as cheap as those time..
Try to source 4g91 gearbox you will have better gear ratio but FC will be a bit high side...
Good Luck..
m@ttz
1,846
13
klang
go find paddle n clutch pump 1st, after dat get e2 gearbox from me, hehe..
roadster182
owh..how much 4 pasddle n clutch pump bro?
any1?
yskyes
18
2
1,503
em...so how much to convert it from auto to manual for putra??? im quite interested on it..
zzainudin
503
Subang selangor
maybe if wanna save the cost go to find it @ chop shop for that all the item needed..i think if u buy with package oso cheaper..but most important thing acctually chop shop got no warannty for that item (take ur own risk) like brother m@ttz said
roadster182
thx bro hehe
so actually how much for new clutch pump ek?
boyzone
2,669
5,148
just go to workshop, they will help u to convert.
cost will around RM 1800 to RM2500 depend of workshop labour cost.
If u look for to have better pick up.. then u should look back ori 4G93 manual gearbox or mivec gearbox.
4G91 gearbox will give lower FC but weak on pick up.
mag9556
2,770
43
1,648
Actually I m using 4g91 manual Gb on my 4g93..
As wht i know pick up is better thn ori 4g93 or mivec coz gear ratio...
yeap...FC...quite high...full tank cant also reach 450km all the way in h'way...
singchaii
687
Pandan Jaya, KL
My cousin putra had just converted from Automatic to Manual transmission.. I forget how much it cost.. But the workshop convert it so neat.. It just like Manual and doesn't look like automatic before.. It done it at Kepong if I not wrong..
boyzone
2,669
5,148
4G91 gearbox Final drive : 4.021
4G93 gearbox Final drive : 4.322
4G92 mivec gearbox Final drive : 4.592.
Base on the Final drive setting, 4G91 should have good fuel consumption compare with others. And of coz, weak on the pick up compare with others.:_:
Btw, do u know ur gearbox code number? When u speed to 100km/h, RPM stand at how many K ?
mag9556
2,770
43
1,648
Gearbox code?? dun know but wht i knoe is I exchange it with my fren 4g91.
100 km/h at wht rpm?? also not sure..family car ma.. cant drive too fast..later ear pain oh... normally drive at h'way at 80 - 90 km/h but didnt have a look on the rpm.. later get bit oh...hahahaha...
drive a lone 1 time onli at h'way.. tested at 210km/h no more liao...rpm more thn 5k...
at the end been overtake by caldina, cant chase it..so, slow down after that..hehe...
m@ttz
1,846
13
klang
wat a waste 4g93 running for 80-90kmh, change wit me la mag, hehe.. btw my 4g92p running 110kmh at 3k rpm, cant read my fc coz fuel metre was crazy, normally +/- RM15 for 100km..
mag9556
2,770
43
1,648
if can i also want to ramp it la...but can not...
later bla bla black sheep....hahahaha....
but my kancil still ok coz use it for work...
mag9556
2,770
43
1,648
Hehe... able to test it yesterday at KLIA H'way...coz go to airport alone...
100km/h is at 2.5k above a bit not reaching 3k...
flat_tyre
88
my satria 1.6 is using putra's manual gearbox. b4, im using putra's auto gearbox. overall, i spend rm1870.
rm1650 for re-con putra gearbox complete set.
rm200 labour cost.
rm20 gearbox oil.
but if u can, do seacrh around for mitsu's 1.8/4G93 NA gearbox at chop shop, better than re-con. re-con item is a bit risky.
m@ttz
1,846
13
klang
mag, ur car more less mine la, but my roadtax surely cheaper, hehe.. right flat_tyre, i didnt believe in recon parts, better buy from chop shop, even 2nd hand/used, but still original, nowadays not only parts been recon, spark plug was also.. bcareful..
mag9556
2,770
43
1,648
hahaha...
roadtax..very big issue here...but still can stand la..
plan to change to turbo liao...as the petrol sucks..rather use turbo cars..nearlly the same..but power wise just like land and the sky...hohohoho...
zzainudin
503
Subang selangor
mag go for kancil turbo laa sure got cheaper roadtax hehehe,
anyway turbo / NA if Remp-It sure got makan minyak meh..
Ineed ur guys help . If I want to modify a GTi engine without changing it . I want to do those things -
-Internal mods like port and polish
-blue printing
-camshaft 272 degree and afew more
After that the performance good liao hah ? Somemore need to do what else ? And does anyone know how much will it cost ? And where to do ? My location is in Cheras . Thanks .
