Can u teach me on performance?
Mywira
93
Everyone here..
im noob in modify performance..
can u teach me how should i modify / upgrade my engine??
Im driving Wira SE,i would like to get more pickup and horsepower,
recently i would like to change the exhaust and add a air filter.
And i also like to change my engine to 4G91..
Do u guys know how much the 4G91?
I heard my fren said there is no different on 4G91 and 4G93,is't true?
Thanx guyz..
Harith
553
B.B.B
bro..
4G91 (1.5 engine)
4G93 (1.8 engine)
BOTH DOHC MMC
between 1.5 and 1.8 here alot of different...
if i were you i would go for the 4G93 engine...
there are no replacement for displacement....
1.8 sure better in term of performance from a 1.5 engine....
cheers..
Mywira
93
bro..
4G91 (1.5 engine)
4G93 (1.8 engine)
BOTH DOHC MMC
cheers..
Erm..thanx bro.
But if i change to 4G93 do i need to upgrade other things?
seanlee
382
3,018
Everyone here..
Thanx guyz..
hahai think he was comparing modded 4g91 and stock 4g93
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
Erm..thanx bro.
yes, engine performance increase, u must also increase ur brakes, suspension and chassis....
Mywira
93
Erm..this 1 sure lo..
How much the cost around to settle this all?
Any brand/type of disc brake n suspension recommend??and the cost of it..
calvin9683
1,768
171
JB
i think ur fren is tryin to say 4g91 n 4g93 LOOK the same....
but performance wise....no man.....
anyway....
ur wira se is 1.5 edi.....
no point changing to 4g91 as i feel there's oni minimal increase.....
go max la....1.8 if u wanna convert.....
then u can choose either n/a or turbo.......
anyway...
ur stock engine is quite new oso ma....
y thinkin of changing????
giving prob???
y not try to learn more bout mods n play wif ur current engine 1st???
abt abs all...
different ppl will hav different set up la.....
v hard to say which is the best....
for brakes.....
normally for wira will just buy from halfcut.......
if ur wira se comes wif 4disc.....dun think u need tis upgrade....
unless u wanna put evo twin pot for ur front la....
rear is more or less the same......
hope these will help.....
just a little bit of my knowledge on wira...
heeeheee
alantan
3,576
15
kl
what fei chai say also i agree...
i readx read read read..cannot understand baru post~
Mywira
93
anyway....
anyway...
giving prob???
abt abs all...
for brakes.....
heeeheee
Is helpful man,
i jz saw many people are using 4G93 so i thought i should change it..hehe
Ya,i'll learn more about mod n play my current engine,
so hopefully all of sifu here can teach me lo..
But 1st wat i wanna do is get more pickup,
How to mod to get more pickup?
Is't need to fit with piston?
Wajafly
159
Shah Alam
Hi.
There's really not much power to gain from a 1.5 Sohc. But if you are serious into modding, I can suggest some significant one:
1. Changing the cam to a racing / street cam. Will cost about RM1500 if I am not mistaken. Power wise should be quite good from mid-high. Maybe increase 10-15 whp?
2. Port polish for smooth power and better torque. Probably a good job will be around 1K.
3. Performance air filter, cold air intake plus lightening your car with carbon fibre bonnet / throw away any woofer if you have. :)
4. Tune the car by installing piggyback / ecu which can control your airfuel and ignition. SAFC only air fuel. SITC is the ignition converter under Apexi. However, e-Manage comes with ignition module also.
5. Use Mivec / bigger throttle body but make sure you can tune it up as well.
Just a suggestion. Don't get conned by those 'tongkat ali' or surbo thing which claims HP increase / pickup increase... Real mods are real mods.
Mywira
93
Hi.
Thanx bro,
thanx for your suggestion...but must slowly mod lo..
coz need much money to mod..hehe
Sarb
68
Mate.. what is your budget? thats the most important thing.. you see i had a good so called cheap car to play with.. but i spent on doing this and that and the total came up to more than my budget.. and i could have done something else one shot!! so you have to line up a budget before you can think of mods.. and moddin a 1.5 sohc is not worth it.. further more you might have to get a new head if u wanna advance your timing or etc cause the distributor setting is locked permanent thanks to proton.. so my advice is save ur money and transplant a bigger CC or do minor modifications where later on you can transfer all those mods to your new bigger CC engine..
eg. airfilter and big air ram(airfilter pipe going to your throttlebody), grounding, probably throttle body bore(better intake), spark plugs, plug cables, exhaust sys & extractor, buang your catalyzer... all theses are min mods..
calvin9683
1,768
171
JB
hmm...
from ur other thread....
ur car stock edi can reach 220km/h wor.....
how u read the speed wor???
if i not mistaken wira se meter till 200km/h oni right???
Wajafly
159
Shah Alam
For a standard 1.5 Sohc, reaching 220 is really impossible... Come on... My company wira 1.8 Dohc able to touch that but takes some while. Exceesing that requires down slope. :)
zzainudin
503
Subang selangor
hohoho std 1.5 can reach 220kmh...well u all can imagine how fast that car (with stock engine)..
that day i try race with other member (x kenal pun) @ highway..i think his had a modding 1.6cc but still cant reach 190 kmh
fu-yohh
A Post Every 5 Mins
door to door service.. stubborn windscreen watermarks remover.
only need 15 minutes of your time
Satisfaction Guaranteed
RM40 per car / MPV RM60
Klang Valley Area
CALL 019-3636 883 Steven
Call for enquiries. Plz do not SMS . Thanks.
