satria gti check engine light issue
Ranjanmax
121
hey guys, recently have check engine light issue after long drive. driving midway on highway and check engine light came out. car was running fine and did not have any signs or feeling or jerks, constraints, etc. i remember having tps issue before as the connection was loose before. Now the connection is good and still cant figure out the check engine light issue. Air flow sensor seems fine, just havent cleaned it cause i dont know where to get the cleaner. Spark plugs havent checked, injectors also havent checked, but dont feel like the engine is hesitating either. any idea whats going on? :smokin::Stupid:
alcyon
800
153
543
I dont know which generation mitsubishi yours is, but you need to find out how to pull/read the codes. The system is telling you something is wrong, but until you actually get the codes you won't know. Go find out how to get the codes. You either need a obd2 reader, or you bridge diagnostic port and read blinks from check engine light like in 80's and early 90s toyotas. I cant tell you how to bridge diagnostic port on mitsubishi as I am only familiar with toyota.
Reactions: Izso
Ranjanmax
121
will do.. mine is year 2000 if that can help..
hye......selamat hari raya....i'm a new member here..need some advice and help...i just bought this HKS 5 Point Grounding Cable Kit and want to DIY into my Perdana V6...so can anybody advice me how to install it?...i mean the right way to install it (this cable where...this cable which one...so on)...if it is possible provide me with a diagram or photo of complete Perdana V6 installation...it'll be huge help for me...thanks
