Is Repairing a GSR turbo bearing experience?
Crankshaft bearing I mean.
Test drive a friend car hearing the ka ka ka sound like bearing gonna rosak
turbo bearing or crankshaft bearing... x sama tau.
both if fail, sound is the least of your concerns
Turbo he juz recond
Is the crank shaft bearing
Crank shaft bearing by itself is friendly to the wallet. Crankshaft bearing + if crank journal damaged + while u r at it stuff + overall labour is not that friendly to wallet.
This is how i gauge repair cost;
1.search for the parts price online inclusive of consumables related to it (gasket maker, seals, gasket, oil, fluid )
2.Add some to each parts cost. If minor parts i will add RM50 and below, if major parts will add up to RM200 to RM500 as most workshops will mark up.
3.Add few more hundred for labour.
I did this by comparing older repair bill esp the labor cost and always estimate higher. Easiest way is to ask a rough estimate from workshop. I did the estimation myself because i want to see if its worth it to DIY. If that time my pocket is deep, I will just send to shop and say the magic word 'buat lah, xpe buat pelan2 tak urgent. dah siap nanti call'.
by time it makes a racket, its not gab be friendly liao.... tbh unless theres an oil pressure gauge, i wouldnt be able to tell that its failing
somehow... this thread cannot... i can upload on the other thread too.
Test, test, okay woh.......:driver:
Wira update
My car bonnet lock middle piller patah,cannot close it. Luckily near my got a kilang doing paint & service car. RM50 job and good to go.
And also I found out my wira is hard to start after 2 day didn't drive. Everything is ok but juz hard to start. Everyday I need to let it warm atleast 15minute.
Wira update
Get Bosch C3 or C7, i have 4 cars at home, forklift, all used it, damn worth it for RM220. If hard to start hopefully its just not enough electrical power la
Yah, with this mco dragging to 60 days, even my China Mari charger being used every 2 weeks to charge up my cars......
The problem is I drove it everyday, every morning I start It juz cannot start. I need to wait until hot afternoon it only will start. Last time send to mechanic also the same problem but after checking all the wiring all ok,nothing wrong.
Have you tried different ways of starting the car? Meaning like my VR, I start without stepping on the accelerator, but once it ignites, then I dab the accelerator. Like my Hyundai i step slightly on the accelerator, then start.....
once announced EMCO... i charged my power bank battery jumper... ever ready in the car... LoL...
eh.. same here. I don't leave it in the car though, very scared it'll explode from the heat.
I've had this problem before - turned out it was just bad battery connectors and dirty terminals. After I cleaned out the battery terminals and replaced the connectors with new ones all problems solved.
Ok,I will go and check agn for any bad connection or dirty terminals.
couple of things to check, see if the terminals are loose enough to move without any tools - if yes, then tighten them. Check to see if the contact is corroded or just worn flat or black or something weird looking.
If not remove the connector, use some sand paper to clean the contact points on the connector and the battery itself. Make sure there's no big black patches (oxidation) or weird coloured parts or something.
Thi isn't my picture but mine was very similar to this. Also the contact points inside the connector itself was browning copper coloured. o I just changed the whole thing.
