KHNG940413
668
56
johor bahru
Wira update
My car bonnet lock middle piller patah,cannot close it. Luckily near my got a kilang doing paint & service car. RM50 job and good to go.
And also I found out my wira is hard to start after 2 day didn't drive. Everything is ok but juz hard to start. Everyday I need to let it warm atleast 15minute.
Reactions: minibeany
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Wira update
Get Bosch C3 or C7, i have 4 cars at home, forklift, all used it, damn worth it for RM220. If hard to start hopefully its just not enough electrical power la
Yah, with this mco dragging to 60 days, even my China Mari charger being used every 2 weeks to charge up my cars......
KHNG940413
668
56
johor bahru
The problem is I drove it everyday, every morning I start It juz cannot start. I need to wait until hot afternoon it only will start. Last time send to mechanic also the same problem but after checking all the wiring all ok,nothing wrong.
Have you tried different ways of starting the car? Meaning like my VR, I start without stepping on the accelerator, but once it ignites, then I dab the accelerator. Like my Hyundai i step slightly on the accelerator, then start.....
once announced EMCO... i charged my power bank battery jumper... ever ready in the car... LoL...
eh.. same here. I don't leave it in the car though, very scared it'll explode from the heat.
I've had this problem before - turned out it was just bad battery connectors and dirty terminals. After I cleaned out the battery terminals and replaced the connectors with new ones all problems solved.
Reactions: KHNG940413
KHNG940413
668
56
johor bahru
Ok,I will go and check agn for any bad connection or dirty terminals.
couple of things to check, see if the terminals are loose enough to move without any tools - if yes, then tighten them. Check to see if the contact is corroded or just worn flat or black or something weird looking.
If not remove the connector, use some sand paper to clean the contact points on the connector and the battery itself. Make sure there's no big black patches (oxidation) or weird coloured parts or something.
Thi isn't my picture but mine was very similar to this. Also the contact points inside the connector itself was browning copper coloured. o I just changed the whole thing.
Dear all sifu,
I had used a machine to polished my black car, but end up when under the sun i saw alot of swirl and it disaster. anything can help to restore back in lower budget type instead of sending to detailing shop
