Which setup will save my fuel more?
Jun 2, 2021
2
23
Hey guys, im using Saga VVT 1.3
My exhaust setup for now is only change stock muffler to Straight Flow Muffler, the sound is really just nice for me, but the problem is my fuel really drain crazy fast, since im working for delivery stuff, i need to save my fuel, im wondering if i use S-Flow will it save more fuel then stock muffler? Please let me know thanks guys.
brokenjars
229
16
Kedah
How fast is crazy fast?
Stock usually is setup for good fc
Should not make the FC so much worse. Probably you got too excited with the throttle cuz of the sportier sound. Anyway you can try S-Flow or Mugen style twin loop mufflers. I use the twin loop on a different car with satisfactory results, practically no noticeable difference in FC compared to stock but gives nicer sporty sound without having the annoying drones or booming sound.
It will return better fc if your driving style remain the same as with before the mod.
Just like a drop in filter or open pod (proper installation). It should return better fc if your driving style remained. How to remain when the sweet sounding intake begin to control your right foot right?
Ok apart from driver problem - check a few things. O2 sensor? was it relocated or same place? Catcon removed or still there? After changing to straight did you lose low end torque? If you did you probably now throttle harder to move the car which in turn affects FC.
Also changing S flow or straight flow doesn't really change FC much at all. I used to think that but now that I've got one of those valvetronic exhausts on an ancient 20V 4AGE, the straight flows better and has more top end power and makes a lot of noise, but that's about it. I haven't seen any difference in FC.
Oh wheel size changed? Oil changed? spark plugs? air filter? O2 sensor still good? Relocating your O2 sensor up or down the pipe will have some effect on the car either FC or power. Lots of things.
mosesmk
165
32
Selangor
IMHO, i think 1.3 variant mostly design for a better FC. im my experience manual variant have a better FC. anyhow, like some comment before, i depend on your right foot either you got a lighter or heavier and also others criteria. your changing the muffler with decent design or just normal one? for me when someone asking regarding better FC, it quite subjective issue.
Feb 2, 2023
27
Hi there!
Regarding your question about fuel consumption, it is not guaranteed that switching to an S-Flow muffler will result in fuel savings. In fact, the straight flow muffler you have now may actually be more efficient than an S-Flow muffler. Factors such as driving style, road conditions, and overall vehicle condition all play a role in determining fuel consumption. It may be a good idea to consider additional modifications, such as a cold air intake or a remap of your engine management system, to improve fuel efficiency. Additionally, keeping your vehicle properly maintained and ensuring that tires are properly inflated can also help to reduce fuel consumption.
Once again the hills are set to reverberate to the burbles of V8’s and boxers as well as the straight gunned with the Berjaya Hills Time Challenge 2010 that will be put together by JPM Motorsports over the weekend of 29-31 October...
