aiya~I not pandai to see the caliper to be honest with you. SO i need to use google to hlp me convert.HahahahahaConvert? No need. It's listed there on the caliper as 1.75 inches
I think FB group is where you want to find.Hahahahahahello.. any 4g13 geng here?
already open new thread.. mayb can talk ther?I think FB group is where you want to find.Hahahahaha
but you can still ask anything regarding car. I think other sifu will try to answer you.
From the photo you shared earlier, the reading on top are Empirical while the bottom one is Metric.aiya~I not pandai to see the caliper to be honest with you. SO i need to use google to hlp me convert.Hahahahaha
So I assume is a stock exhaust pipe I guess?From the photo you shared earlier, the reading on top are Empirical while the bottom one is Metric.
Each small line on that scale is 1/16 of an inch. The next line is longer and denotes 1/8.
Starting from the 1" mark, you count the lines and arrive at 1 12/16 which simplifies to 1 3/4 which is 1.75 inch
Super stock. Time to upgrade. Hehehehe... if you change extractor get a tuned length 4-2-1 and then 2" your piping, add a middle resonator (straight flow tabung type, not those stupid swirl bullets) to reduce the drone and add a straight flow rear muffler. The bigger the better for a nicer tone and less noise.So I assume is a stock exhaust pipe I guess?
Sound very poisoning.....Hahahahaha.Super stock. Time to upgrade. Hehehehe... if you change extractor get a tuned length 4-2-1 and then 2" your piping, add a middle resonator (straight flow tabung type, not those stupid swirl bullets) to reduce the drone and add a straight flow rear muffler. The bigger the better for a nicer tone and less noise.
Even straight through rear muffler, after a while the fiber glass disappears the sound will change. Mine changed completely, but then mine close to 20 years already......lolSuper stock. Time to upgrade. Hehehehe... if you change extractor get a tuned length 4-2-1 and then 2" your piping, add a middle resonator (straight flow tabung type, not those stupid swirl bullets) to reduce the drone and add a straight flow rear muffler. The bigger the better for a nicer tone and less noise.
ini macam tabuliSound very poisoning.....Hahahahaha.
I juz saw a 4-2-1 extractor stainless steel one.
something like this
Buy, Sell, Find or Rent Anything Easily in Malaysia | Mudah.my
Find almost anything for sale in Malaysia on Mudah.my, Malaysia's largest marketplace. Happy Buying and Selling!www.mudah.my
Is it ok I use it and sambung back my ori pipe or juz do a set of new exhaust is better?
To me I want a deep tone sound. Not those prangggggggggggggg when you tekan minyak and this is what my car sound now.Even when you up shift your gear it will have the pop sound. I think I am at the age I feel pranggg sound is to annoy to me.HahahahahaEven straight through rear muffler, after a while the fiber glass disappears the sound will change. Mine changed completely, but then mine close to 20 years already......lol
Which mean I need to do a new set piping if I use this extractor?ini macam tabuli
If want to do might as well complete the whole thing......lolWhich mean I need to do a new set piping if I use this extractor?
Mine very deep bass sound. If alarm with motion sensor, even if I drive pass slowly the alarm will go off......hahahhaTo me I want a deep tone sound. Not those prangggggggggggggg when you tekan minyak and this is what my car sound now.Even when you up shift your gear it will have the pop sound. I think I am at the age I feel pranggg sound is to annoy to me.Hahahahaha
yea. if use existing maybe ada power loss. a proper set may be better. IMHO. i am still learningWhich mean I need to do a new set piping if I use this extractor?
You can - not to say you can't. But I've never used this brand before so I don't know how it affects performance. It looks like a Jasma brand extractor.Sound very poisoning.....Hahahahaha.
something like this
It's not a must la. You will feel a difference but maybe minor differences. If you do up the whole thing then that's a different story. But performance gains from modding exhaust isn't big. It'll just feel "lighter" or something like that. Not lekat kerusi differencesWhich mean I need to do a new set piping if I use this extractor?
he measure his muffler tip lah. not the piping.I think the 2.5 inch is the outer diameter of the piping. Then inner will be less than 2.5inch. It depends on the wall thickness always measure inner bore for more accuracy if cannot then you measure the OD then wall thickness then you get the ID because your exhaust flows inside the tube not outside. I have came across 2.5 inch piping on OD and ID only 2 inch.
Works better if you look at the picture he shared. Look at the vernier caliperhe measure his muffler tip lah. not the piping.
Because stainless steel got many different thickness other than diameter some they use wrong type of stainless steel.that is a seriously thick exhaust. Half an inch thick
Ok,noted the Powerzone one I also saw it. The seller say is 1.8 inch need to mod abitYou can - not to say you can't. But I've never used this brand before so I don't know how it affects performance. It looks like a Jasma brand extractor.
Compare that Jasma with this :
4g13 4g15 Powerzone Extractor (Proton saga, iswara, wira, satria) | Lazada
Buy 4g13 4g15 Powerzone Extractor (Proton saga, iswara, wira, satria) online at Lazada Malaysia. Discount prices and promotional sale on all Exhaust & Emissions. Free Shipping.www.lazada.com.my
This is the Powerzone one. The way the collectors merge is different. Powerzone is a more reputable brand but if you got budget have a look at Supercircuit exhausts as well. They can do the whole exhaust. There's a few brands out there - you need to get opinions from people who have used them.
My old car had the whole exhaust done by Everco way before they were expensive. I had the front to back done for 1300 back then (close to 20 years ago).
Similar threads |
L |
