Help with new absorber and spring hitting fender
boygenetic
17
Wow, that's several inches of drop
this is hows it looks like now. my initial paint job budget went to replace the suspension system.
paint job can wait.
looking into strut bar and rear subrame.
not sure if the rear subframe a gimmick but the Anti roll bar is hella expensive.
paint job can wait.
get the antirollbar FIRST!
strut bar and subframe bracing doesnt do much if to be honest....
ARB is more expensive due to its function
Agreed on this.
Got extra budget get front upper strut bars. Vios are well known for its numb drive feeling. Having a more solid front end will transfer more feel to the steering.
Reactions: boygenetic
boygenetic
17
Look at the design, which one is more solid for its purpose?
its the ARB right.
Just imagine the right hand suspension is compressed, the ARB design is more efficient in doing the job. The subframe wont do much...like having a solid axle.
THOSE SUBFRAME IS PIECE OF SHIT very useless thing that only makes your car scrapping everything on the road...not even functional as anything... seriously...
its actually they mimicking proper antirollbar of UR instead...not other way around...
this is main function of antirollbar: https://en.wikipedia.org/wiki/Anti-roll_bar
ARB is connected to the absorbers or wheel control arm usually right? The name itself "Anti roll bar" says a lot already.
That other thing is more of a torsion beam strengthener which is really no point.
boygenetic
17
PERFECT !!!! thank you all for the reassurance !
so...16mm or the 19 mm? :biggrin:
Also its RM450 for the 16mm (on average).........sien !
sup all- got a 4g93 sohc out of a 93 eagle summit dl. replaced head gasket and timing belt. got timing belt on marks lined up start car all is good but engine vibrates at idle. Read in manual that silent shaft could be 180 off causing this but what i not understanding is how to verify this or how to fix it seems to me that the tensioner is what needs to be adjusted but it just bolts into the block so i confused. help please. thanks in advance.
