myvi 1.3 first gen cant accelerate above 120 km/h
Triple Y
37
another question here will it be better for me to change to straight flow exhaust as the power range is like stock? Because i think the swirl bullet n my sflow is holding to much back pressure?
110-120km/h, rpm at 4-5k n the car feel a bit heavy at that time. engine oil i think is addinol semi synthetic forget what already
Then I think is GB problem. At 110kph should be like 3k rpm, let bro. Izso confirm since he have Myvi too
jerrysiow
407
146
Seremban
TS, check your overdrive enable or not. Your engine RPM seem very high for 110-120km/h. Myvi auto should be around 3k RPM at 110km/h and 3.5k RPM at 120km/h which is lower than manual myvi.
I have same problem.
my 2010 Suzuki SX4 can go past 160km/h, although it takes a while to get to that speed.
last year I change my battery to NS60 equivalent (SX4 use NS70), and suddenly it gets very hard to get past 160km/h.
Is this somewhat related to changing battery? I also change the spark plugs to more expensive one, recommended by mechanic, i dunno the brand of the spark plug.
Battery has nothing to do with it.. mostly. But you need to explain how "difficult" it is to get past 160. There's a lot of reasons for this. It depends.
Check the weight of the oil la. And it sounds like you have the OD button switched off. Switch it on la. It's the button on the gearknob. That's ridiculously high RPM for that speed leh.
might be spark plug problem
Unlikely. If it was the plugs, you'd have misfiring or jerkiness.
Don't touch your exhaust la. I'd remove the bullet though. You don't need so much stuff in the way.
leinnz
333
57
3,028
what about the AFR, did he clean the air intake portion? mine was sluggish before and after cleaning the AFR, the car performs as per normal
loose_end
3,649
197
Malaysia
If car jerk, vibrate, hesitate to rev at 4k at 120km usually due to plugs. If plug done, could be fuel filter or fuel pump.
Triple Y
37
throttle body, air filter cleaned and the car fill slightly better for the moment. since i started this post before i went for major service... will try n see if accelerating to 120km/h will be smoother.. thank you all
Triple Y
37
might be spark plug or fuel pump n fuel filter just change. spark plug just change to denso iridium spark plug but feel the throttle pedal slightly heavier..
sweelt
Nov 6, 2016
2,306
248
must use overdrive ah cant use d to drive up to 120km/h?
overdrive very confusing, whatever term for car lah. Button near gear knob.
When OFF overdrive, rpm sure high. Don use always, more load to gearbox. Plan to cut 15 cars, use loh...hahaha
When ON is normal driving rpm according to throttle.
But auto trans, once you step on the throttle it will jump to lower gearing dy.
TS driving an auto. Might be gb problem. Final gear not kick in ?
or he was driving with OD-OFF all these while
leinnz
333
57
3,028
please do try. it might be the reason
When ON overdrive, rpm sure high. Don use always, more load to gearbox. Plan to cut 15 cars, use loh...hahaha
When OFF is normal driving rpm according to throttle.
You got it reversed, Overdrive ON lowers thew rpm.....:driver:
Done using 3/8" thick plywood... bought from a hardware shop near my place in serdang... de board itself costed RM35 n RM5 for transportation... measuring 4ft x 8ft...
Took me one day to cut de board n complete de hinges n "door".. then another half a day for carpeting it... a lot of work... but very satisfying DIY... B) :tb:
Steps n procedures are here : http://khguan.fotopic.net/c806091.html
