Triple Y
might be spark plug problem
110-120km/h, rpm at 4-5k n the car feel a bit heavy at that time. engine oil i think is addinol semi synthetic forget what already
Then I think is GB problem. At 110kph should be like 3k rpm, let bro. Izso confirm since he have Myvi too
If can get the gear ratios, then can calculate what the rpm should be at specific speeds for each gear.
I have same problem.
my 2010 Suzuki SX4 can go past 160km/h, although it takes a while to get to that speed.
last year I change my battery to NS60 equivalent (SX4 use NS70), and suddenly it gets very hard to get past 160km/h.
Is this somewhat related to changing battery? I also change the spark plugs to more expensive one, recommended by mechanic, i dunno the brand of the spark plug.
another question here will it be better for me to change to straight flow exhaust as the power range is like stock? Because i think the swirl bullet n my sflow is holding to much back pressure?
must use overdrive ah cant use d to drive up to 120km/h?
TS driving an auto. Might be gb problem. Final gear not kick in ?
TS, check your overdrive enable or not. Your engine RPM seem very high for 110-120km/h. Myvi auto should be around 3k RPM at 110km/h and 3.5k RPM at 120km/h which is lower than manual myvi.
throttle body, air filter cleaned and the car fill slightly better for the moment. since i started this post before i went for major service... will try n see if accelerating to 120km/h will be smoother.. thank you all
or he was driving with OD-OFF all these while
overdrive very confusing, whatever term for car lah. Button near gear knob.
When ON overdrive, rpm sure high. Don use always, more load to gearbox. Plan to cut 15 cars, use loh...hahaha
When OFF is normal driving rpm according to throttle.
But auto trans, once you step on the throttle it will jump to lower gearing dy.
You got it reversed, Overdrive ON lowers thew rpm.....![]()
Similar threads | |
Y | |
Similar threads | |
