But you have to look out for Penang TT woh!......lolWill keep an eye on the forums about TT bro...
Which is like very rare??But you have to look out for Penang TT woh!......lol
Not sure, probably you can post a tt thread for Penang and see the response......Which is like very rare??
Will look into it.....Not sure, probably you can post a tt thread for Penang and see the response......
If cannot find ask the importers.....Just asked for monroe reflex abs at a spare part shop. The owner told me even he couldnt find it. haha! Will try asking other shops too and will try to save more money till then..
I have emailed the person in charge...If cannot find ask the importers.....
http://www.monroe-sea.com/distributors.html
I just remembered another brand that I remember using that was slightly better than Monroe. Sachs. This brand was quite good in terms of stiffness and car control. Maybe you'll have better luck finding this brand.Just asked for monroe reflex abs at a spare part shop. The owner told me even he couldnt find it. haha! Will try asking other shops too and will try to save more money till then..
That's quite cheap, brand new set?If you're under a tight budget can consider HWL adjustable with hi/lo/soft/hard... 15 steps version less than RM1.5k.
Yup brand new since now competition is quite high for shocks, you can get these kind of prices for entry level Hi/lo/Soft/Hard wth 12-16 steps adjustableI just remembered another brand that I remember using that was slightly better than Monroe. Sachs. This brand was quite good in terms of stiffness and car control. Maybe you'll have better luck finding this brand.
Hope food items can go down like this, but fat chance.....Yup brand new since now competition is quite high for shocks, you can get these kind of prices for entry level Hi/lo/Soft/Hard wth 12-16 steps adjustable
Does spare part shop carry this??or must look for performance shop??If you're under a tight budget can consider HWL adjustable with hi/lo/soft/hard... 15 steps version less than RM1.5k.
Ok sure....Which one will u recommend between the HWL h/l/s/h, and the sachs? cause u always recommend to get coilovers with h/l/s/h..so i just wanna make sure that..I just remembered another brand that I remember using that was slightly better than Monroe. Sachs. This brand was quite good in terms of stiffness and car control. Maybe you'll have better luck finding this brand.
---------- Post added at 10:47 PM ---------- 6 hour anti-bump limit - Previous post was at 10:38 PM ----------
---------- Post added at 11:34 PM ---------- 6 hour anti-bump limit - Previous post was at 10:47 PM ----------
Ok, will try to look for HWL and for proper installer...If the HWL is within your budget, make sure you buy it from a person who'll help you install properly. Preload the spring tension, adjust the bodyshift height (if the HWL has that) and replace the absorber mountings. The dampening rates can be adjusted yourself after everything is done.
A poorly setup coilover is kinda pointless too. If you don't have an installer who can do all that properly, you're better off with the sachs / monroe. Cuz preloading and bodyshift isn't something you can do on your own unless you have the time and the tools.
This can be done by Izso auto and gang if doing DIT......hhahahhahahhahaIf the HWL is within your budget, make sure you buy it from a person who'll help you install properly. Preload the spring tension, adjust the bodyshift height (if the HWL has that) and replace the absorber mountings. The dampening rates can be adjusted yourself after everything is done.
The Monroe or Sachs are OEM replacement means you cannot adjust the height, damping etc.Ok, will try to look for HWL and for proper installer...
