Need help from Neo members
Zack Zikry
From Facebook
Oct 2, 2011
14
30
Selangor
www.facebook.com
hi semua, salam 1 malaysia. Saya ada masalah sikit dengan kereta sy. saya guna proton satria neo 1.6 auto. campro tahun 2010. kereta saya ni topspeed 160-165 kmh jea. rpm baru 4500-4600. tapi kaki cecah lantai dah. macam x logik pulak neo 1.6 punya topspeed mcm tu. So, sp2 yg ada pengalaman bole laa share dengan sy, harap otai2 neo dapat bantu sy. Terima kasih, Salam 1 Neo
es2611
953
175
Re: Perlukan otai2 neo untuk membantu
cuba RON100 drpd PETRON 15 Jan ni. hehe.
Veloc
3,235
991
Sabah
So what you expect is the normal top speed for neo auto? 250?
Zack Zikry
From Facebook
14
30
Selangor
www.facebook.com
Atleast 170-180. Just same in brochure
---------- Post added at 10:20 PM ---------- 6 hour anti-bump limit - Previous post was at 10:17 PM ----------
At least 170-180. Just same in brochure
How is your car condition, fully standard or already using big rims and/or have heavy speaker box inside? Try testing when the fuel level is below half to make it lighter.
Would not help if the engine doesn't need such high RON requirement, it'll be just a waste of money.
Looks like the engine is a bit tired.
Just like 6UE5t point in his question, the condition plays a major role.
It should be able to clock at least 170kmh on gps if everything is well.
Zack Zikry
From Facebook
14
30
Selangor
www.facebook.com
Fully standard.
What should i do?
Any recommendations?
---------- Post added at 02:26 AM ---------- 6 hour anti-bump limit - Previous post was at 02:24 AM ----------
:( yeahh it should be, but what should i do? Someone told me I should do PDT tune. Should i? Cause only pdt tune can tune up vdo siemens computer box
30,002
Try locking in 3rd and drive. See can reach red line or not. If can, then only switch to D and see if you can go higher speed.....
---------- Post added at 09:56 AM ---------- 6 hour anti-bump limit - Previous post was at 09:54 AM ----------
Yup, agree that the engine do not require higher Ron will be a waste of money....:driver:
Waiora_ProTuner
619
221
mine can only reach around 160km/h, stock standard under 10,000km....
after some mod can only reach 190km/h...
130hp, big speaker box, 16 inch rims and leather interior...
similar to Neo CPS...
i bet changing to manual and reduce weight can go over 210km/h...
ken yeang
6,618
1,327
a standard neo like TS's car, will be floaty when doing 150.....so, I'll be careful driving such speed or higher....
Waiora_ProTuner
619
221
True that...can't just bought a car and test its top speed...
RON97 definetely helps...they develop the engine during that time...its show some difference at top end on dyno...
Remove all unnecessary things (reduce weight)
check tyre pressure (a bit high can be good)
clean all filters
change all oils (engine and ATF)
reset ecu
clean cars inside out
do some high speed/rpm runs (clean of carbons)
find flat route (bandar saujana putra to KLIA, kesas klang area, guthrie (not flat but empty), mex)
wind up windows
off aircond
and go...
Zack Zikry
From Facebook
14
30
Selangor
www.facebook.com
Yup, i can reach red line in gear 3, but not in D :(
---------- Post added at 11:20 AM ---------- 6 hour anti-bump limit - Previous post was at 11:15 AM ----------
Yes, i can reach redline in 3rd gear at 145++kmh but not in D
Veloc
3,235
991
Sabah
Usually what is advertised in the brochure is a bit optimistic under ideal conditions. Or maybe its a theoretical top speed. Wind speed and direction plays a huge role as vehicle speed increases. Also weight. And if the engine is tired, a little bit of compression loss has significant effects.
BFX73
116
13
Hi TS,
am using a neo but the manual one...the top speed that u achieve is normal for neo auto...so dun be sad...if u thinking to gain more topspeed that means u need to spend like hell lot of money...a fren of mine modded his neo campro auto and the result are not to his liking...some of the manuals with simple mod can outrun his modded campro auto...finally he got himself a manual tranny...
simple mod to make ur auto campro feels more power
drop in air filter
bored or change the TB
get CPS injector and a better fuel rail
better plugs
lightened crank pulley
a good set of extractor (tuned length) from reputable brand
a must have ATF cooler
downsize the rims / suggested 15" with 195/50 or 55 for more comfortable daily drive
and by doing the above, u can feel better throttle response wit minimal impact to the topspeed...to gain more top u have to mod the engine...
---------- Post added at 12:44 PM ---------- 6 hour anti-bump limit - Previous post was at 12:43 PM ----------
where do u live bro?
Zack Zikry
From Facebook
14
30
Selangor
www.facebook.com
Hi TS,
drop in air filter
better plugs
Thanks for explanation, I lived in subang.
A minimal of increasing topspeed? 180kmh-200kmh?
BFX73
116
13
maybe 165-170kmh or maybe no diffrence at all...
u need more horse to gain more topseed + the auto are not helping much...by changing to manual and it gonna cost u about rm2-3k u can maybe get 190-210kmh n thats the top for manual campro 1.6 neo in stock standard...
A Post Every 5 Mins
there are quite lots of confusions and questions before i take the words from vrturbo.... since into mod.. just do it... then i did it today:smokin:
BEFORE
AFTER
instead of some blink blink effect and more neat looking, what i feel is increase in engine response:driver:... at least i noticed that my boost kicks in earlier 300-500 rpm than previous plug cable set up... normal around 3500rpm 0.7bar full now around 3000-3200...
