First Impression: RCS Suspension - Velocity Sensitive Dampers
Jonnip
Feb 27, 2014
17
6
503
Well. Let me know if they honor the warranty of their old product. As I said in the beginning it's a great product. Just don't expect it to last long. Or be safe.
Sent from my iPhone using Tapatalk
Sad to hear for your bad experience though. I just installed their product on my Forte and im a very satisfied customer. From stock suspension to RCS. The difference is like day and night. The suspension is a secondhand from my friend. I got it installed from a tire shop and got some noises here and there also. I think its workmanship issue. Im going to RCS and have then check and rectify the sounds.
Sent from my GT-I9500 using Tapatalk
But you say they change name from RCS to RDS. Do they still honor the old brand?:confused:
---------- Post added at 06:11 PM ---------- 6 hour anti-bump limit - Previous post was at 06:10 PM ----------
Oops, we had the same question on mind.....:driver:
Jonnip
Feb 27, 2014
17
6
503
Hi
Ok i spoke to an ex worker. Actually this is the situation as i understand it.
Feezam has opened a new shop called RDS in U5 Shah Alam. And yes he does provide aftersales support for RCS suspension. With that in mind i am willing to give feezam a try, i dont want to knock his shop before he has started. the original post made it sound like it was the same company with a different name.
ixeo
4,788
3,080
KL, Malaysia
They are bankrupt? Didn't know that. Avoid like the plague.
Zanskie
Mar 5, 2014
14
503
Im not sure why for the brand change. But they sure honor their workmanship and support for their old products. I think that RDS will be operating under the same people, hence the product.
Actually it takes a long time, much effort, lots of sweat & money to bring up a new brand (Name). Either it is not doing well to have the name changed but good to hear that they still honor the former brand on after sales service....
Out of curiosity can I ask what car did you have the suspension installed on? I know someone who abuses his RCS on his Satria and doesn't seem to have any issues at all considering how rough he is with his car.
Zeroshift
133
13
3,018
Basically from what i know, RDS actually is being operated by the Staff who used to work with RCS. Their previous partnership somehow did not work out hence clayton & nanda did not continue with the brand. But they still give advice to the guys at RDS from time to time. But no worries, they are still supporting their existing customer and they are still selling new struts..
ken yeang
6,617
1,327
What about the prices of the "new" RDS components? Are they priced similarly to RCS?
I guess many customers dont mind paying more, provided the quality stuff they get is good as it claims.
Thanks for the info.....:driver:
Zeroshift
133
13
3,018
Not too sure about the price for new component, but i think it should be cheaper than RCS as the operation cost is not as high as before. Now small little shop only.
Quality wise i can't comment as have yet to see the new product. Still quite new though for RDS, around 2 months max i guess..
keni988
10
I was shocked to know this. My RCS dampers had similar clik noice last Nov, I drive to Bukit Jelutong to check and they say no problem. Then I go to few workshop to confirm again sound is from damper. Go back to see Clayton and re-service the front dampers and so far ok. Only issue now is if my car full load, car body will hit rear tyre...
Are your wheels offset far out from wheel arch, or suspension setting is very low?
microfibers
Microfiber Explained
micro fiberWhat is Microfiber?
Imagine a microscopic plastic wire that cuts through and breaks apart dust, dirt, grime and moisture, and then picks it up like a magnet without scratching the surface. This is what microfiber does when cleaning. Our microfiber is a revolutionary thread, comprised of wedge-shaped polyester filaments and a core of nylon. Made of both oil-attracting and water-attracting polymers, the fibers are woven into masses of...
