facing a problem no car enthusiast should ever face
Supra_Fanatics
20,673
3,998
Cockroaches got fangs meh?
Belum cuba, belum tau. Once try, Hari-Harimau :biggrin:
---------- Post added at 09:59 AM ---------- 6 hour anti-bump limit - Previous post was at 09:58 AM ----------
I thought you will say, ask him buy you lunch, then you spray for him.......hahhahhahaha:biggrin:
---------- Post added at 09:17 PM ---------- 6 hour anti-bump limit - Previous post was at 09:16 PM ----------
Spraying in air con vent, actually scare the chemical stays in the vent and is not good when using the air con. Scare also the chemical mix with the wet damp internal then turn bad smell also...:banghead:
---------- Post added at 09:18 PM ---------- 6 hour anti-bump limit - Previous post was at 09:17 PM ----------
you got kids, meh?:confused:
---------- Post added at 09:19 PM ---------- 6 hour anti-bump limit - Previous post was at 09:18 PM ----------
You point to the car, they give you quotation loh!.....hhahhahahhahah:biggrin:
Not me la, Izso la.
Swifterific
174
30
mothballs. drives out even spiders, ants, any bugs out of the car. but only can be applied by leaving your car under the sun at least half a day, and requires you to take them out from the car and air-out the car remove the toxic vapor out from the car.
and I despise spiders 6x more than roaches.
mothballs are the white balls that smell like an old almari right? i've done that too. i put so many in my car for a day or two. apparently it wasnt enough siiigghhhhh
Pray that the roach did not hook up before die....hahaha.
Roach do bite and thats a fact.
Which is why i hate them.plus,they kind stink and very2 brave with human.
Very unsafe if suddenltnit attack u whil driving.
dude dont say such things maaaannn you'll just scare me enough to never drive my car again :bawling:
Bro swift,
The vent is the one that control aor circulation.
Either internal circulation or allowing outside air in.
The knob or switch is the one labelled with an arrow getting into the car or u shape arrow.
most of the time cable operated vent have this problem.if u used it frequently,it wont shut properly.i diy shut on my blm and my sis kenari.
Most of the time the air intake is located under the plastic trim under the windscreen wiper.
If u want outside air after shutting the vent,just wind down the window then.I will diy for my wife viva soon and if i dont forget i will post step in this forum.
ahhh that thing. i always have it on to internal circulation. does that make the vent open or closed? closed, right?
That makesnthe flap closed.try not to use it frequently as the cable or mechanism can get some freeplay and will cause the flap not closing properly.one sign the flap is not closed priperly is u got outsode air smell getting inside the cabin despite using aircon and all 4 windows up
Yup, all my older cars have that problem. I manual completely seal it up too, so cannot use for outside air anymore....:biggrin:
We'll see tomorrow. The fella's hopefully joining us. However I hope the roaches in my house don't decide to migrate to his car. HAhah
Probably saw your last post then did not turn up......hahhahahhahaha:rofl::rofl:
Swifterific
174
30
I was too late :bawling::bawling::bawling::bawling::bawling:
anyways, i hope the peace contract between me and the cockroaches are still strong. or not i may have to actually burn the car.
Supra_Fanatics
20,673
3,998
Sell and buy Satria Neo R3 or Fiesta ST xD
hi guys,
is it really important to rotate ur tyre on certain times? im running on kyb rs abs in front (means short stroke)and standard abs at the back, with 15' rims.
i found out that my kyb rs cannot support bigger tyre series, only 50 below, since im using 15'... now, my front tyre is 50/15, rear tyre is 55/15... :P
