Air flow meter upgrade
boyzone
All sifus,
I plan to go with S90 @ 70mm throttle body and aftermarket aluminium intake manifold to match with my Deratech cam.
Meanwhile, is upgrade on air flow meter is necessary?
If needed, what is the air flow code number is good to upgrade?
Also, changing in bigger air flow meter will make the engine run lean ?
Please advise and educate... Thx.:adore:
I do not understand...y need to change the air flow meter? If the desired air flow is within the air flow meter range, then no problem isnt it? After all, the purpose of air flow meter is to read the air flow only..it wont increase or decrease the air flow...correct me if i were wrong
y not get a SAFC?
Penang do not have good tuner ... I prefer to let my engine run with stock ecu as I believe stock ecu can cook this minor mod :biggrin:
Upgrade air flow meter is because of need more air on wide open throttle after change to oversized throttle body and intake manifold. With more than 20% of oversized, afraid air volume of stock air flow cannot support. :hmmmm:
what car???
if proton 1.6/gsr use same air flow meter....which is 1 on n.a engine and another on turbo engine...see...afm not that restrictive....its actually quite capable to support mild-mid engine upgrades...
unless u were talking about 2bar boosted engine then i would discard the afm and use MAP sensor with standalone anyway (or atleast e-manage)
what car???
Hi Pomen,
Currently run with 4G93P with duratec mild cam inside.
Stock air flow is 455.
there's no need to upgrade your MAF. Each old mitsubishi airflow sensors are very dynamic of its base tuning threshold and capable of huge amount of 'tinkerings'.
Note : there is a screw at the bottom of the MAF sensor. Screw Out for leaner AF mix or Screw In for richer mix. A 455, or can work as well as GSR's 449 as long as the tuning is matched for accurate airfuel ratio. But then again, on stock ECU, how your injector works to richen or lean out doesn't only depend on outputs by MAF... it will also calculate output from the oxygen sensor and your TPS. Conclusion? Only disturb the MAF after everything else has been tinkered with.
kopi...the screw adjustment on MAF is new to me...any picture to share?
I dont happen to have a pic of my own but I'm borrowing from Google. The screw is sealed with somekind of polymer sealant from factory and you need to peel it off to reveal the screw. It's not usable with flathead or phillips screwdriver since the screw need a special tool to rotate it, but you can work with chiseling a little bit of the screw surface to accomodate flathead screwdriver, as I did.
The screw is actually an airflow restrictor. Turning it clockwise, is called closing and NT clockwise is opening. Closing seems to be making richer AF mix, while opening sends the mix to the leaner side. I had once fully open the restrictor and my plugs went white.
Noted.
I just bring in an E-manage in-order to gain more accurate on AF and ignition tuning.
However, will go to change my piston to increase my compression ratio before send to tuning.
the question is:
- what piston head should I put ?
option 1: piston from 4G92p SOHC
option 2: TOTO for mivec aftermarket piston with 1mm metal gasket
And estimate what is the compression ratio can I get from the set up?
Please educate... Thx
have u open up your head before..
if not mistaken 4g93p piston same with 4g92 sohc piston..if 4g93 japan single cam piston will be flat..
before this using mivec piston on my 93..dont do compression test by the way..ask few tuner also they said too high compress they dont dare to tune..without tuning my 93 sure have knocking going uphill..better ask your tuner first..
No, didn't open engine head to check on the piston design.
Maybe will go to option 3 : thinner head gasket without touching the piston.
My mechanic told me not to touch the MAF, very sensitive. My friend destroy one before....:rolleyes:
while u open the head can do pnp also..
Think not to go port and polish as my area do not have expert on this field.
Btw, what is stock gasket thickness? Any idea? Please advise.. Thx
How oversized is oversize for u...is this ok... 4" OD Custom Aluminiuim AFM...ha ha:biggrin:
me not so know..but for u need in volume for air flow u still need to think about how speed the air will create an enter to get more volume,and stableize etc...is that all in big size like T.B, I.M with short and big runner will make more air volume to enter in cylinder..:hmmmm2:
For the I.M,u still can mode its with cut and port, oversize a bit for the plenum and get match flange for the T.B...
BTW this is good discussion in here..keep it up:rock:
My intake manifold already changed to 93T intake. Also, ported to match with 6A12 throttle body.
With stock ecu + 272 cam, only manage to produce 145whp@160+nm of torque with Ron95 petrol :banghead:.
Next is plan to put in 4G92p piston + e-manage.
A thread every 60 seconds
