Quebec Has Just Banned Hellaflush
Supra_Fanatics
20,685
3,998
Yup, pillowball mount can adjust camber from the top.....:biggrin:
Then can use back normal screw adi...screw the camber screw lol!
---------- Post added at 04:21 PM ---------- 6 hour anti-bump limit - Previous post was at 04:21 PM ----------
Can adjust as you like..... :driver:
Mood say, OH, I want -2 la today, then set lo -2.
For unker days, I want +2 la then :thefinger:
Then rear also can adjust? :hmmmm:
LucasChng
113
27
DELETED
To be able to adjust camber have to have camber screw right? Sorry newbie here :smile:
Front you have to add, rear depends. If its independent rear suspension, then they all come with camber screw. Thats why some vehicle have 4 wheel alignment, some have 2 wheels only.
Mostly vehicle frt come with macpherson strut. Rear suspension like myvi, & saga blm, they are consider dependent rear suspension or aka beam axle suspension. Rear camber on the vehicle of this suspension can't be adjusted. If you see they have kangkang before, stay away.. Itu DIY, likely to fly off, they mod it on the knuckly area there. Or maybe just potong & burn back the rear beam..
30,002
You know how much the pillowball ones?:biggrin:
Rear depends, Tiggo and Hyundai both can adjust alignment and camber in the rear...:love:
7,514
haha..whenni was staying in balakong sure there is atleast 10 favourite corner nearby...at ktm station, after besraya toll, mines flyover to balakong, near kg malaysia-kuchai lama and sg.besi-jalan istana...hard to resist not to enjoy those spot :rofl: but now in sendayan still gome some interesting corner but not that heavy load...plus now got uprated arb front and rear...maybe need to tone down a bit my camber setting :biggrin:
but first thing first must change worn steering rack, work front absorber topmount and swap into softer spring...maight go as low as 4k springs at front :driver:
ericmaxman
Senior Newbie
664
216
Compared to bro. SF RM45 ones....:biggrin:
---------- Post added at 10:14 AM ---------- 6 hour anti-bump limit - Previous post was at 10:13 AM ----------
Always delay action mah! Probably now only start to check....Raya and Kopi oh?
I wonder what RM45 type he uses :rofl:
Veloc
3,235
991
Sabah
"Low and slow" "i love haters"
Beeech pls... Its "lowlife and slowlife"
my turtle is a iswara 1.3-stock engine, recently i found tht my brake is not good enough.. is there any upgrade can solve this problem?? Of course i'm looking for cheap solution la... heh heh...
is changing the brake hose to steel type will bring significant effect? How much is those stuff?
thank u...
kam siah...
