Optimum Coating : 2 year old Nissan Teana Renewed
s1tl
1,237
1,019
Ipoh/KL
We have here a 2 year old Nissan Teana, looks may be deceiving at first but when we explore closer, the damages found were rather severe. The owner briefed us about the usage of his car and the care he had taken on the car. Apparently, the car was only used as a point A to B vehicle to work. The car is always parked under a fully shaded area and the exposure to UV is minimum. That explains the glossy and shiny finish.
From the looks of the car, it had a good definition in gloss and reflection.
A closer look and we found the usual dirt and sand on the car.
On the roof, we found some light watermark stains.
Some usual road grime on the rear end of the car.
We went on to check the paint condition. The typical condition after 2 years of improper washing.
There were some severe and obvious scratches too
On the other panels, there were a consistent swirl damage
The owner then briefed us that there were some feline friends that always liked to climb on his car which also causes some damages
More cat scratches on rear section of the car
We started by giving the car a good a deep wash that it had lacked for the past 2 year. Removed some tar stains and some tough rain marks on the drainage area. Then followed on to the paint correction. Here we can see the front right fender prior correction.
After correction been done.
More afters shots on different panels of the car.
The cat scratches before.
Cat scratches after.
Zoomed into with a led to check on the fixed scratch.
A final shot of the before on the front hood
And the Afters
We gave the car another wash with a mixture of wax and grease remover to stripped the polishing oil.
Finally, we did a alcohol wipe down to totally remove all polishing oil, This is the water beading of a clean surface before coating.
We gave the wheel some attention although its not a branded or expensive wheel. It looked faded, without shine, without gloss, with no attraction at all.
After we cleaned the wheel, dried the wheel, we gave it a new layer of Opti-Guard.
The water beadings on the wheels.
Finally after 10 long hours, we completed the entire coating procedure. As usual we will not caption the beautiful and glossy final shots for your viewing pleasure.
s1tl
1,237
1,019
Ipoh/KL
Supra_Fanatics
20,673
3,998
Izso sure get poison since he has the STD haha! Nice job bro. Got chance need to learn from u haha
s1tl
1,237
1,019
Ipoh/KL
Supra_Fanatics
20,673
3,998
Whats STD?? Sexually Transmitted Disease?
Nissan Syphilis = STD :rofl:
Sounds nice actually.
Like Subaru Impreza WRX STI & Nissan Syphilis STD.
s1tl
1,237
1,019
Ipoh/KL
s1tl
1,237
1,019
Ipoh/KL
Hai to all sifu.....
i need some advice abt wastegate...im using 6A12TT n planing to put wastegate coz my boost right now was not firm...no stable at all...some time can go at 1.2 n after i reach to the top of it suddenly the boost runing down to 1.0..
i ask my pomen n req me to used the external WG for both of the turbo...n also advice to used 35mm...
if im using a WG,those it will iincrease my hp?
what is the pro n con if im using 2 WG?
