Brittle Spark Plug Leads
unker no working meh?
if im off sure will drop by....
Now work Auto DIY mah!.....:biggrin:
Kaotim for bro. SC already. Need to break the pieces to smaller bits then attach water hose to vacuum hose and vacuum them out. No place for even chop stick to go it. Plug blocking the way....
y no col me datang? :biggrin:
You already know mah! and you say you free, you will come..........:biggrin:
---------- Post added at 10:06 AM ---------- 6 hour anti-bump limit - Previous post was at 10:04 AM ----------
I come kacau only. If i were to do alone, I would have did it in another harder way ahah
I was already working on my car mah! so is no kacau, if not won't call you.....:biggrin:
Whether hard way or not, now done.....:driver:
stupidcar
5,000 RPM
5,567
850
Haha but those stuffs arent with u when u are doing ur car, need to take out.
Thanks anyway. :biggrin:
No problem, vacuum and electric extension only....and you are welcome.....:driver:
---------- Post added at 06:14 PM ---------- 6 hour anti-bump limit - Previous post was at 06:14 PM ----------
must belanja unker banana leaf :rofl: got 1 very nice near his hse.
Kavita....:biggrin::biggrin:
---------- Post added at 06:15 PM ---------- 6 hour anti-bump limit - Previous post was at 06:14 PM ----------
Hahah can can. Btw, I'm shopping for 2 good used tyres. If can I drive u 2 or the others also we go shop lo. Only if VR is free of course.
Why used?
stupidcar
5,000 RPM
5,567
850
Why used?
This month dunno when to take leave. So can use it on weekdays, see which days both of u free ahha, then Kavita no problem.
Used because budget tight ma. If can find some nice tyres why not. mainly because u told me RM100 for 90% u got it last time tempted me. :laugh:
That one so happen some one trade in and I was there at the right time....:biggrin:
However nice tyre should mean plenty thread pattern, right? because yours 60 series hard to find nice tyre as in performance...:smokin:
DanzEterna
15,910
3,371
www.primeperdanaclub.com
Why used?
not sure is it kavita or not but its facing the school just a few hundred metres away from your hse.
---------- Post added at 09:08 AM ---------- 6 hour anti-bump limit - Previous post was at 09:07 AM ----------
unker got lubang for cheap used tires ah?
im also interested.
Changing the size of the tyre fitted to the car can improve vehicle roadholding and other handling aspects. Most frequently the new tyres that are selected have an increased section width (they are wider) and a lower aspect ratio or profile (they have a lower sidewall height).
But there's a few things that you have to know about when swapping-in bigger tyres. Firstly, increasing just the width of the tyre while retaining the same profile will cause an increase in the diameter of the...
