Noisy at 70km/h and above
heryky
May 3, 2012
29
So... the car (Toyota Vios '07) has new set of tires (with reasonably latest manufacturing date) recently. The front tires were changed first and it was alright (no noise at high speed). Then, I shifted them to the back to make way for the another new pair in front.
All of them are Continental CC5 and stock size (185/60/R15). The old ones were Bridgestone RE080.
Then... the noise started to become obvious. It is akin to standing in a wind turbine whenever I accelerate to 70km/h and above. I'm suspecting the sound comes from the tires because if the speed is below 60km/h, it is quite silent.
Any thoughts?
g88
3,082
54
5,148
Any thoughts?
u sure is tires sound or door/windows seal sound ?
15,390
Wind turbine noise la taiko g88. Nothing to do with seals liao.
heryky : Have you checked the wear of the new tyres? I assume camber, alignment, etc are all good? RE080 to CC5 is kinda extreme. CC5 tyres are somewhat... meh.
RE-080 even though is from BS Potenza range but this one special made for OE fitment and label Sports performance with ride comfort, do you think is good in performance?....:hmmmm:
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
does the sound like those army trucks @ high speed, if it does usually the tyres, have u checked the tyre rotation is it correct, have u tried to swapping those tyres vice versa. previously I used simex tyres & it gives those army truck sound until I changed to powerblitz the sound is no more. using NCT5 front & Roadstone rear now & no sound oso.
Yup, can be tyre uneven wear or even wheel bearings then....
DanzEterna
15,910
3,371
www.primeperdanaclub.com
usually if above 80kmh should be your wheel bearings.
by jacking your car, turn your wheel manually & u will identify the problem or ask your foreman to do it.
dear sifuses,
my problem is, the starter wont stop working even when the engine already starts, even more surprisingly it's still working when I turned off the key. thought it was the relay problem, changed wit my horn relay still problem persist, spent a bit more & use a new 1 just making sure & stil same problem, it even burnt my jumper coz starter wont stop, luckily nothing severe happened, if the other car engine wasn't running bet it'll drain the batt 2. any thoughts @ this...
