Rubber coating for rubber trim
cbsteh
310
144
543
Kazakhstan
www.christopherteh.com
My rubber trim especially around the windows tend to have water spots and "polka dots".
Today I saw a rubber coating that came in a spray can. You spray and what comes out is like paint but after drying for 4 hours, the paint-like appearance is actually a thin film of rubber. Although it can be peeled out, it takes some effort to do so - like tearing out a very sticky film.
I am wondering if I can apply this coating on my car rubber trim especially those around the windows. However, the spray goes over a large area, so could I spray into a can then apply the coat by brush on the trim?
Kindly advise.
ken yeang
6,618
1,327
Most of the rubber coating (should I say film) that is sprayed on. Plasti-dip is one kind.
There is another type coating that is applicable by either dipping in can with liquid rubber. It can be brush-on. It is then air-dried.
The dipping is used to coat handgrips of tools, and non-slip surfaces such as floors...etc.
Add more coatings to increase rubber thickness.
I say plasti-dip can be used for coating rubber trims, but it wont last for years.
I think it is better than the normal spray-on rubber-black aerosol though....
g88
3,082
54
5,148
Kindly advise.
Try look for Carmate Black Resin Restore in Eneos
diyrubberpaint.com
Jan 2, 2014
12
503
hi
do you have some pics of your rubber trim that have the water spots and "polka dots"?
Supra_Fanatics
20,685
3,998
You can actually try using plastidip. Easily get at Ace Hardware. Since is also rubber paint and easier to tear and reapply anytime.
Safe to use.
mokh
226
14
i used black matte sticker to solve the problem.
still looking good after 2 years.
cbsteh
310
144
543
Kazakhstan
hi
No, I didn't take a photo, but mine looked similar to this but with more pale greyish spotting:
Safe to use.
Yeah, that was my initial question I posted if anyone had done this before ...
Yeah, I did consider this but this was my final option if I couldn't get my rubber trims looking good more permenantly. I used Aerospace 303 before. Good but not so permenant. Need to reapply every 3 to 4 weeks.
GRexer
GRexer™ KuzTomZ
1,201
10
Puchong
If you're in Klang Valley, I don't mind giving you some Duragloss #271 Rubber Trim & Tyre Dressing to try on. I usually keep it in a 40cc spray bottle.
diyrubberpaint.com
Jan 2, 2014
12
503
you can just cover the edge of the rubber trim with masking tape and spray the rubber paint around it. once done, just remove the masking tape and peel the unwanted rubber paint.
btw, i think if use rubber paint also will not give you permanent fix as it will last 2-3 years based on the manufacturer guarantee. If you are lucky, it can last more than that.
For permanent fix, maybe u can just change those rubber trim. go to any windscreen repair workshop and they shall able to change them.
cbsteh
310
144
543
Kazakhstan
Thanks. What I meant by "more permanent" is longer than a few months. Even if I have to reapply the treatment after one year, this is fine with me because this will be better than what I was doing before.
jonlsl
Jun 18, 2012
36
16
508
Bro cbsteh try using vinegar to remove the water spots first. Then once clean and dry I suggest you use Vaseline and apply working into the rubber. See if it works for you. I learnt this from a Porsche owners manual. :proud:
Mr. Solarturbine....is there anything wrong with you, your hand or your head?
WTF!!, are you doing keep simply disliking other people's post even disliking the forum R&R. You just do for fun or what? Yup, you've got my attention and You're not gonna like it. I've seen your way of replying to other people's posting and its really childish and F**king stupid to me....If you are having erectile problem then I advice you better don't come in here, if you are a wannabe super negative...
