Cant remove key from igntion & car cant startup.
swgiant
May 11, 2013
27
Car already off and in "P" position, cant remove the key from ignition. Then try to start the car again, failed. Only cranking sound. Also try shift the gear up & down from P, R, N, D, 1, 2 but still cant startup and key still stuck inside. I only can remove the key when I disconnected battery + - terminals. Seems like safety feature jammed there.
First thought was battery fault but foreman tested the battery still in Green Zone, voltage still in healthy. Could it be alarm anti-theft feature ? But my alarm is very simple and basic, which does not come with anti-theft feature or cut fuel feature. Now the alarm is not functioning together with center lock. When I pressed the alarm to lock/unlock, it got lock/unlock mechanical sound but center lock still maintained in 'locked' position! Therefore, i have to unlock the alarm just to disable the siren, then manual unlock the car.
Whats problem there? Wiring problem ? Ignition switch problem ? Gear Shift cable problem ? Car already towed to workshop. They mentioned need to take time to diagnosis. :confused:
swgiant
27
almost a week past, car still in the workshop. Car can start but remote lock/unlock is not functioning. Have to press the remote to disable the alarm's siren then manually unlock the car. Tauke is busying...
DanzEterna
15,910
3,371
www.primeperdanaclub.com
try to find a button located next to the ignition, u might need to press it at the same time & remove the key.
---------- Post added at 10:44 AM ---------- 6 hour anti-bump limit - Previous post was at 10:42 AM ----------
also try turning the steering wheel from left to right & vice versa & remove the key...
swgiant
27
received a phone call from foreman, he mentioned the main relay already spoilt. He recommends me to replace a new set as the existing is quite fragile and weakened by the infirmities of old age, 23 years already. It costs me RM 400+, have to wait 1 week for stock arrive.
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
in that case make sure u r there when they r goin to replace the relay coz if it's not the prob u r paying them for nothing.
Calling all Audi TT mk1 owners here,
the car is not in the teens of its life,
care to share the issues that you might face at this time and age?
I m planning to buy a 2nd hand model and just would like to have a feel of the faults out there to prepare myself.
Ive read all the good parts about the car jus wanna know the cons now
Maybe you can share on where old cars like these can be serviced as well
Thanks buddies!
