What is tyre flex?
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
sounds fun...
Supra_Fanatics
20,673
3,998
I can bring mechanic jack and jackstands no problem.
Erm.. Will need to plan with you. PM you (whatsapp la)
Don't forget to whatsapp me too :rofl:
Supra_Fanatics
20,673
3,998
Your VW selling already mah! still need fitting meh?:rofl:
My Jetta never tried 17" before ma. Wanna try before selling. See if it looks better even with stock absorbers. :biggrin:
Supra_Fanatics
20,673
3,998
Both of mine are on standard height suspension looks okay also mah!.....hahaha:rofl:
Lower it la bro, got better aerodynamics and more stable :biggrin:
xtremeleo
3,247
464
5,183
tyre flex, either caused by the softer tyre walls or u got higher profile tyres. add more tyre pressure for d fun factor, but not too much
Hyundai on stock suspension, cannot lower. Rear actually already lower due to it's weight.
VR on adjustable but already at it's lowest setting. Could be rally specs...haha since VR used for rally those days.
Front tried to lower before, when too low drive shaft runs at different angle a lot of vibration....:banghead:
So all standard now....:driver:
Already at 240kpa pressure. Any harder I might hit the 280kpa maximum limit.
A very noticeable problem would be the delayed steering response.
I don't have delayed response at all. It feels like the cars rear ass weight suddenly shifts and then the car squats one side which in turns corners in harder than expected. It's good but somewhat unpredictable. I haven't been able to master it so I want to get it out of the way. Would you say this is tyre flexing?
Supra_Fanatics
20,673
3,998
Rear lower then your front is higher...:rofl:
Maybe aerodynamics not good also partly for high FC?
So far my PP2 dun have tyre flex, in fact cornering was much more fun than cornering in BLM or Altis...but comfort wise, kelisa is the worse :laugh:
Yup, springs in the rear mighty small compared to the front. Of course front still have engine weight but then I think the rears springs have weaken. Trying to mod my old VR suspension in....:driver:
Good for cornering sure bad for comfort....:rolleyes:
Supra_Fanatics
20,673
3,998
Dunno which blog I went, said kelisa best not to use GAS Absorbers...not comfortable. but mine using gas...SACHS Absorbers.
Cornering improved due to the Stiff Rings installed also less dashboard vibrations when driving thru speed breakers...last time vibration was so bad as if is gonna come off....everything rattles...
Partly also because of tyres good for good handling :rofl: But tyre wall for PP2 shud be hard Guess which is why it doesnt flex much. comfort level acceptable though.
Probably because yours are 55 series. I have seen a PP2 195/60R15 those days sidewall quite soft, though the pattern area is hard....
Supra_Fanatics
20,673
3,998
yes is 55 series. Never thought 55 also can start to feel uncomfortable. Compare all 3 cars going over uneven roads on the same road, kelisa can feel the most of it while BLM and Corolla go thru it without feeling much of it...
My Corolla also is using 205/55/16. 55 series as well. BLM is 185/60/14. Shud be the springs that makes some difference i guess...
Yup, springs and absorbers too. I think you mentioned using gas shocks, right? Gas are harder as they have compressed gas inside...
TitanRev
Mar 3, 2005
8,180
3,678
VR, nvm...let SF lower his car kao kao so he can start thread in forum....My drive shaft got sound....pls help..
I lowered my car also don't lower much...try to let the drive shaft level on both side and the steering tie rod don't have too much angle.....now my driveshaft is level and tie rod end angle very little only....my car lowered but still able to clear bumps without needing to snake...
ixeo
4,788
3,080
KL, Malaysia
Moral of the story: Change one variable at a time. lol.
So what's the outcome?
Seeing more and more Porsche Panamera's on the road? It is no wonder when one realizes that this year alone, Porsche sold record levels of units here in Malaysia. The relative popularity of Porsche's here is giving comparative car marques a run for their money.
Report by The Car Guys for Zerotohundred.com...
