Airtrek issues and uk parts
scrappyloz
Nov 7, 2013
12
503
Hi guys I just brought an Airtrek Turbo R, its a pretty rare beast here in the UK with only 30 ever having been imported.
Im struggling with a few parts and problems.
I know I have a large boost leak from what I believe is the pipe that runs over the rocker cover from the inter-cooler to the turbo, as someone has made a home made piece of pipe which sucks. Im really struggling to track down an aftermarket part or original pipe here in England.
When my car is cold it struggles to idle and cuts out frequently. When its at running temperature it idles at 1500 rpm.
Does anyone know if the airtrek windscreen is the same as the Mitsubishi outlander.
With regards to the original blow of valve can i just replace this with an after-market part or does it cause running issues.
Cheers for the help
stutzedward
3,416
561
A set of custom made inter cooler pipes with 2 sections (turbo to inter cooler & inter cooler to throttle body) is rm450 before postage. It's custom made. They're stainless steel and comes with 4 Samco connectors with clips. Sold quite a few sets here. If you want original rubber ones, I have a set lying in my store room which u can have it just for rm100 without postage.
I believed cw2u outlander is the same as Airtrek except the lamps and bumpers.
I'm using hks sqv but it stalled me many times until tuning was right. 4G63T is not good with vent off bov bro.
---------- Post added at 07:06 AM ---------- 6 hour anti-bump limit - Previous post was at 06:11 AM ----------
scrappyloz
12
503
Cheers for that I would be interested in the samco and stainless set. Any idea on cost of postage to the UK? id be happy to purchase them of of you.
Regards to the exhaust system is it standard evo as my rear box fell off last night :( and id like to get a stainless replacement.
stutzedward
3,416
561
I've sent to New Zealand before and the cost of postage was around RM190. Will arrive within a week as it's by Air. To UK, I think it will be slightly more but won't be too much I am sure. Maybe around RM250-280.
scrappyloz
12
503
Can I PM you with my address so you can get me an accurate total inc shipping? Cheers
russellc2
Sep 14, 2012
13
508
Wellington, NZ
Quick question while you are awaiting the new intercooler piping to turn up - have you checked and cleaned the MAF sensor? I had some weird idling issues on mine with no boost leaks that were fixed with a can of MAF cleaner :)
Cheers,
Russell
scrappyloz
12
503
Cheers,
Russell
My inter-cooler piping has been made up by a previous owner and it is terrible and leaks like crazy. So it has to be replaced eitherway.
Regarding my idle issues i believe its a dirty throttle body and icv.
Does anyone know if an evo 7 exhaust will fit as a replacement
scrappyloz
12
503
Big thanks to stutzedward who has sorted my intercooler hoses which will be with me shortly :)
My exhaust is now re-welded and no longer broken or blowing.
I really need a 100 percent correct answer on what windscreen is the same as my airtrek. My windcreen guy says the part numbers are different between the outlander and airtrek screens so cannot be sure if it will fit, any idea if they are the same
stutzedward
3,416
561
Hope the pipe solves all yr problems bro.
We don't gave Outlander here. So can't check bro. Sorry.
scrappyloz
12
503
Hey all,
My first post here, purchase my airtrek the other week and love it.
Lots of knowledge and info on here!
Op - try xtreme motorsport in midlands
Welcome to Xtreme UK, The UK's premier supplier of previously cared for performance cars
They imported them originally ... otherwise take it to autoglass ask them to order... if they get the wrong part they will have to sort it out.
Hope this helps
Unfortunately i cannot seem to get hold of xtreme for some reason. Their phone hasnt rung for weeks
Sampir_9992
Dec 23, 2013
6
Hi bro...interested with the custom ss intercooler pipes. still available.........newbies here
scrappyloz
12
503
Right new inter cooler pips arrived before Christmas but I have only just fitted them tonight. Seems to boost up a lot quicker with no leaks which is nice.But still the car seems to struggle after 2nd gear and seems to surge and be lower on power than it should be.
Also found that when I was pulling into a road I floored it and at around 5000 rpm the car accelerated really well and made a large fart like noise. Which im assuming is the bov (Dump valve).
I feel the bov might be leaking and maybe a MAF related problem as well. I have a boost gauge lying around somewhere which I will fit to see if im dropping large amounts of boost and ill get the part number off of the maf and order a replacement.
Il have to look on eBay and find a sutable bov replacement. (Any ideas on what is ok for use)
Also cleaned my icv and now it idles :)
stutzedward
3,416
561
bro, you can try looking for stock BOV from Evo 8/9. I think they hold the boost better than stock Airtreks. I am using SSQV, not much problem with boost other than unstable on high boost cos I am still using the original actuator. An external wastegate is advised if I want to boost high.
The intercooler piping helps a lot in terms of response. You will feel it even more during hot days where the rubber becomes spongy and expend pretty much during high boost.
Barely than a week after we drove the 520i, BMW's F10 picks up the award for "Luxury Car of the Year" at the 2012 Frost & Sullivan Malaysia Excellence Awards. The award recognizes companies that demonstrate outstanding achievements and superior...
