Kembara dvvt in dire need of help..
fazidk
413
5,183
Hi guys...like d topic says d car is in need of help..u c it's leaking a bit of engine oil (it's just been thru a major overhaul in s'ban)..from Wat I can see is that it's due to d cover x 'gummed' properly (apparently there's x gasket for this therefore use only sealant)..sounds ez enuff rite??thats Wat I thought..d problem is I x get d crank pulley off!!manually wiz hammer..FAIL..air gun..FAIL..it's like d pomen who overhauled d car put in loads n loads of glue..:(
Honestly I've sent to pomen n he gave up..stil had to pay for labour tho :(
Anybody????heeeeelllpppp
punk
360
76
Negeri Sembilan
Crankshaft oil seal leaking?
u diy opening crank pulley bolt?
The belt might slip u know, if u dont know what u r doing.:biggrin:
fazidk
413
5,183
It's x d oil seal (from what I can see)..x la I sent it to workshop they x open it even wiz air gun..I x know how to explain :hmmmm:it but it's like trying to remove valve head cover but in this case have to remove d pulleys 1st..
punk
360
76
Negeri Sembilan
U mean want to take off the timing belt cover rite, but before that need to take off the crank pulley off.
kembara is running on timing belt?
Better don't do it, if u never diy timing belt before. u might slip one tooth on the timing belt if u turn wrong direction.
fazidk
413
5,183
Yup bro I think that's d cover:)..using timing chain tho x belt..x planning to DIY (unless got sifu to help la)..
I knew it was coming, I mean you cant be that famous and get away with doing something like that. Someone is bound to spill the beans. If Michael thought he could get away with it by paying the cabby a very generous 100 Euro tip, he obviously got it wrong.
The cab driver, a certain Mr. Tuncer Yilmaz sparked a frenzy of international headlines when he revealed that Schumacher, the retired seven time...
