Got car wiring problem, where's the good wireman?
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
My brake lamps are not functioning....:bawling:
My third brake light is missing....:bawling:
My reverse lights are also not functioning....:bawling:
My fuel gauge meter is also not functioning...:bawling:
Can anyone recommend a good wireman in KL, PJ, Subang or Sunway areas? :hmmmm:
Someone whom can do the job fast, and not too expensive charges....:biggrin:
ColdPlay
288
112
Sometimes, it could be down to fuse or worn out and exposed live wire touching metal parts.
In my case, lighter port's fuse keep burning no matter what device I'd been using. Getting fed up and
DIY checking the culprit, turn out the rear 12V port's live wire is touching the metal due to previous foreman did not mask and align the wire properly.
You can try A & H Automaster in Bandar Tasik Selatan. Find them on Google Map.
Look for Syafiq. Reasonable charges and result.
Was accidently bump into A & H while waiting for my car ready at Mr Alex @ 1JZ expert guy
as his workshop is located just in front.
LesleyAprotto
Banned
1,339
287
683
Thanks CP for the reference.
Another thing I would like to share is the
Faulty fuel meter gauge.
If its not working, the meter showing at E, then all you have to do is to fill up the tank.
When the tank is full, the float will just pop up and thats it!
Its working again....
So no need foe costly repairs....:idea::biggrin::smokin:
faruck
861
46
selangor
depends on what car u drive bro?? :hmmmm:
fazidk
413
5,183
Hi bro Lesley...theres one in damansara (behind damansara specialist hospital)..I've known d guy since I started 'playing' cars..it's a father son biz..
LesleyAprotto
Banned
1,339
287
683
OK Bro Fazidk, will check them out these few days...
Installed the 3rd brake light, but because my rear windscreen is curved, the double sided tape cannot stick properly and it dropped...
They rewired the brake lights, cost me RM30 for rewiring, and RM20 for chaging two bulbs and installing the 3rd brake light.
I bought it for RM 26 its a ten bulbed LED light.
Reverse light still not functioning....:mad::rofl:
djrev
46
IN MY HOUSE LO
Hi Im having same issue. not sure if need to do whole rewire or only which ever necessary. Did you manage to find a good wireman?
Need to respray my car inside & outside. Has anyone here got any good recommended place where i can go?
