I don't think i can explain it clearly because all of it are in my brain. And i am bad at explaining. Btw, i am lazy to take the pillars apart again just to show u guys the pic, haha, and I am out of free time. Hope this post helped u later on.
Okay, 1st, open the dome light using a flat screwdriver(test pen) or whatever that is that fits the hole.
Then grab any wire u can find around your house. I used my broken laptop charger wires. Best to follow the colour of the wire and follow which wire is suppose to which(live, earth, neutral is not needed.)
Open both split ends. Just use scissors and paper knife. If you haven't tried this before, cut it slowly then u will learn slowly. U can see u did a good job because none of the copper wires were cut out. Cut it longer to have more space to do your work later.
Now you need to test out which part of the bulb is -ve and +ve. So, pandai pandai lah, okay? Not being lanci here but some of the things u need to learn by urself in order to learn/adapt quicker next time. Mostly is common sense.
Now, hook your wires with ur bulb. I used a 5SMD LED bright white. I myself hate blue, red, or any other colours than white and warm white. In my world, the colours mean lala(typical chinese style, aka ah beng).
You hooked it already right? Please hook it accordingly to avoid burning any fuses, i burnt my memory fuse.
SWITCH TO OFF POSITION
Take out the ori bulb by pushing either one of the metal part. Now u can on it again because we need to test out which part of your bulb holder is neg and pos. Test it using the wires that are hooked on to ur bulb. Only 2 tries are needed. *Common sense* :proud:
When u found out the position, switch it off, hook the cut split ends in to the hole of the bulb holder.
Thats basically it. How you hide your wires and bulbs are all up to u. I drove the wire in the roof 'carpet'(as u can see from my pic), thru side pillar, in the door rubber, then under the dash.
Happy DIY! post your pic of your final result. :cool:
