4g92 SOHC non Mivec Head + 4g93 block
Nov 5, 2012
4
Indonesia
Hey this is my first post :D
i want to ask can 4g92 sohc non mivec with 4g93 complete block(crankshaft,piston,etc) work?
because i have tried mod my 4g92 engine with open apexi filter,4-2-1header,1,75 inch piping(std is 1.5 inch),porting polished,skim the head 0.5mm,engine balancing and blueprinting,lightened flywheel,piggyback dastek
and i dyno the car with RON 95 fuel and just got 142.9HP/6200rpm with 159NM/5100rpm on engine, standard is 115hp
3 years ago i dynoed and got 142.8Hp with RON92 fuel i think worn piston ring and valve thing caused this but no white smoke comin to the exhaust
so i really want to try 4g92 head+4g93 block really bad...
can you all give the comment for this type of frankenstein?
thanks :D
syimirmazlan
Apr 25, 2012
36
10
508
thanks :D
wow, real nice specs u have there.
and quite powerful from a 4g92 sohc.
rezaieuo
4
Indonesia
hi..
since this is ur first post..welcome to zth..
im not really sure about the conversion, but u may ask few sifu here..??
http://www.zerotohundred.com/newforums/car-modification/7445-4g92-dohc.html
yes i ask many forums in internet but nobody have the right answer i think
hey thanks :D ,just wanna try 4g93 block and see how much improvement i will have :D
the exact result i'm not sure....but if u retain the 92 piston would yield better result due to higher compression piston than 93....(they share same size)
but most probably u'll get more torque improvement over hp improvement.....but with proper port size and camshaft spec. who knows......
maybe u can search for MHtuner or mal auto garage for this job.....
rezaieuo
4
Indonesia
thank you i immediately email them after i see your post :D
rezaieuo
4
Indonesia
sorry i forgot about the timing belt my tuner tell if i want a 4g92 non mivec head with 4g93 block i should find a correct timing belt because it doesnt match if i used 4g92 and 4g93 timing belt
so which timing belt that match with 4g92 head and 4g93 block?
thanks
I've been around this corner for very very long time taking in details and all your guidance.. But I have one massive issue. I've been trying to detail my own ride. How to clay my car? I've clay very very long and many many passes at the lower arches near the wheels and its really hard to get it off. And can anyone recommend where can I get OPC or Detalien products? Thanks :)
