HELP!!is 4g92 sohc ecu same as 4g92 dohc??
peterj
1,321
258
1,683
Kuching
currently plan to swap sohc to dohc to gain some respond and power, however, i just wonder is the ecu same between dohc and sohc?? really confuse cause the seller keep claim same, pls help all sifu:adore::adore::adore:
GEFORCEXTREME
151
13
I'm not sure but no is my guess, since 4g92 SOHC cuts off at 6.8k RPM, a point where you haven't even get the most out from the DOHC head which is at 7k RPM according to Wikipedia.
Please raise the rev cut if you're planning to do the swap, also if possible, throw in some MIVEC pistons. ;-)
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
which 4g92 doch??
i only knew mivec head for 4g92 (if got non mivec pls correct me)
thus mivec head use diff ecu from sohc 4g92 :adore:
peterj
1,321
258
1,683
Kuching
yea,non mivec dohc,and now i finding the ecu, code is 8804 or 8843 not sure, saw it in zth post 2006:banghead: any idea to get it or any body got it?:bawling: pls help
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
well.. some trick for mitsu/proton engine can be done to use back SOHC ecu.....
providing that all sensor was same (ignition and injector) u can use back SOHC MAF sensor along with SOHC ecu.... :adore:
about the DOHC head whereabout i donnow.....might be easier to source out 4g61T(1.6T) engine than 4g92 DOHC non mivec head...
i have a pivot megaraizin installed in my car. i noticed that most of the time it shows two readings. 4.7v and 10.5v if i remember correctly. i understand thru some research that 4.7 is the lowest voltage at the start of engine and 10.5 is the real voltage. my questions is how will i know if this is healthy? how will i know if its time to change the battery or my battery has some problems?
i went thru this but still dont get it...
