Air-Cond Replacement Service Charge..
imkelvin
Oct 13, 2012
Helo everyone,
I would like to know is the price reasonable to service and change air-conditioner of Proton Iswara?
Please tell me.
Thank You.
Here is the receipt.
Rily
43
Helo everyone,
Please tell me.
Thank You.
I think they are not cheap, a little bit on the high side. but still acceptable, the labour and a/c gas is that cheap? are you using r12 if you're using r12 gas then the price is reasonable as r134 will cost more.
Cheers.
nyantong
192
50
Come on dude, people have to eat too. In case you don't realise, the value of ringgit has dropped drastically, causing inflation.
imkelvin
Cheers.
I not sure bro, I think it should be r12 bro. Did you mean the replacement parts are quite high?
I am asking it is acceptable or not. Not asking people have to eat or not. Although people have to eat too, I also need to eat too. I don't want to get potong too. You are off topic already.
Rily
43
I actually did some research on the prices, again, they are not cheap, its just the market price, and I think its acceptable... Cheers bro!
expansion valve the bronze color 'T' shape wan ah?
Expansion valve is the one attached to the cooling coil to disperse the gas in cooling coil, as I read his bill and it shows a/c coil and a/c valve so should be that....
If you mean this, with temperature sensor...
jason_lls
7
hi can i ask u a question?
do u ask the price b4 u repiad ur car?
ya the price for me is reasonable bcos it come with 1 year warranty.
How to: Retrofitting projectors
Tools/Materials:
Dremel tool
Sanding drums for dremel
Rotozip bits for dremel
Flat blade screwdrivers
Philips screwdriver
Clear silicone sealant
8 3” screws
Box of nuts for screws
Electrical tape
Epoxy/glue (like jb weld)
Shop towels
A brain
Step one: take your headlights out of your car…DUH!
Step two: you need to take your headlights apart. If your headlights are like 90% of the newer ones out there, you can just bake them in the oven to...
