Enquiry about Saga BLM Disk Brake
willxsky
Aug 19, 2012
12
dear pro, please help me to settle my question :adore::adore: ... i'm using original disc right now, and my rim is 17"
1. i would like to change new disc rator with line 1, any brand recommend?
2. is the clip have to change together compulsory?
3. the from existing set is able to move to the rear?
:adore::adore::adore:
cfphoon
1,857
6
kuala lumpur
1.wat do u mean by 'line 1'?
2.which clip r u referring to?
3.'the existing set' meaning the front set u wanna move to the rear?
ken yeang
6,617
1,327
Based on my interpretation....
He would mean "groved disc", i think.
Think he means "caliper"
Front disc to put at rear wheel position.
Sorry, definitely cannot
willxsky
12
1. Yes, i'm looking for grooved disc, any brand can fit and what price?
2. the clipper have to change 1 set with new disc?
---------- Post added at 02:05 PM ---------- 6 hour anti-bump limit - Previous post was at 02:03 PM ----------
cfphoon
1,857
6
kuala lumpur
i do sell racing rotor for saga blm.. price i already pm u.. no ned change caliper.. but the front u definitely cant move to the rear..
zac
1,347
231
Johor Bahru
Is there any brembo can be modded on? Be it mitsu or Nissan or Toyota. Anyone did this before?
Or any aftermarket multiple pot brake kit for blm?
jaesern
15
9
1,503
first of all, learn all the definition or google it before you ask
1. that disc rotor you mention normally called slotted disc in malaysia; while the one with hole called cross drilled disc.
3. can be done, do you really want it?
can i say can?
willxsky
12
sifu...you're here....hahaha....
---------- Post added at 12:05 AM ---------- 6 hour anti-bump limit - Previous post was at 12:03 AM ----------
can i say can?
please say something you know... i would like to change the disc and clipper separate...can i? got brembo or endless??
jaesern
15
9
1,503
first of all, that thing's you mention called brake caliper. may i know what tire and what brake pad are you currently using?
---------- Post added at 01:53 AM ---------- 6 hour anti-bump limit - Previous post was at 01:49 AM ----------
does your car equipped with ABS?
Supra_Fanatics
20,673
3,998
17inch??? How's the FC like...mind to share? :stoned:
---------- Post added at 11:11 AM ---------- 6 hour anti-bump limit - Previous post was at 11:10 AM ----------
Sorry to interrupt...
What is BLM stands for anyone knows?
Boleh Letak Mivec...
willxsky
12
i'm using 17", brand not sure... Brake pad i forget...it's blue color...
i think it's with ABS too..i'm saga blm base line...sorry i'm quite weak on performance part...
jaesern
15
9
1,503
find out what brand of tire and brake pad you're using first before trying to do anything. especially the tire.
try to use brembo racing, ap racing or project miu performance brakes on a cheapo tire, see what you will get (:
afaik based on Persona, the base line model don't equipped with ABS, proton thinks malaysian's life have no value.
ken yeang
6,617
1,327
Biasa la bro. Export proton gets all the goodies, with cheaper price. While the local proton gets nothing and more expensive.
Just the opposite to japan with their JDM car. haih....Malaysian kana screwed again, again and again...
Hey guys, I have an 05 Camry which is a company car. When I got the car the car has been previously used by another person. So what I noticed was that when I closed the boot lid it sounded very metallic and hollow like closing a standard Viva door with its hollow metallic sound.
Since it's a company car I'm not going to spend loads of my money on a car which isn't mine. So I took this opportunity to try out some DIY acoustic damping to dampen the metalic banging sound when you close the...
