Need advice for sr20det !!!
iceinfire
May 22, 2011
28
503
ENGINE-S13 SR20DET
MOD ON ENGINE- ENGLE CONROD
TOMEI 1.5 METAL HEAD GASKET
SUPERTECH VALVE SEAL
ACL CONROD & CRANK BEARING
WALBRO 255L FUEL PUMP
TOMEI ROCKER ARM STOPPER
ARP HEAD & MAIN STUD KITS
BRIAN CROWER VALVE RETAINER
BRIAN CROWER +1mm VALVE
BRIAN CROWER CAMSHAFT 264in & 272out + VALVE SPRING
ENGINE FULLY BALANCING
HEAD PORT & POLISH
CP 87mm PISTON
S15 TURBINE
3" DOWNPIPE
FRONT MOUNT VR4 SIZE INTERCOOLER
2.5" INTERCOOLER PIPING
3" EXHAUST SYSTEM
70mm THROTTLE BODY
TOMEI ADJUSTABLE CAM PULLEY
BANANA EXHAUST MANIFOLD
GREDDY INTAKE MANIFOLD
ORI S13 INJECTOR
SARD FUEL REGULATOR
APEXI AFC NEO
my mod i haven dyno yet , i jus wana to know all my mod can reach 350WHP ???:banghead:
mines998
1,048
149
I think with decent setting you can get higher than that since you already lower your compression you can got for higher boost to get yr desire horsepower. As far I know SR20 can easily get 400bhp with metal gasket and bigger turbo.
ehdrian
I Don't Care!
3,310
280
1,683
I think u just need bigger injectors+standalone+bigger turbo to achieve yr target or even more..
iceinfire
28
503
i like to hav super good respond so i planning to get garrett GT2871r , around 700cc injector , haltech E8 ..... izit good for my 350WHP-400WHP setup ??? :stupid:
ehdrian
I Don't Care!
3,310
280
1,683
he wants 101% sure kut..hehe
iceinfire
28
503
tis sr20det is my 1st mod car , so i wan to mod untill the most perfect sr20det for me .....
abt the turbine n ecu , wat is the most perfect for me ? tis 2 item i really not sure .....
any way really thanks:love: u guys giv some advice ......
mines998
1,048
149
For turbine you may consider 3076 or if you got budget maybe can go for Owen turbo if you expect higher output and ECU haltech should be ok but tuner is more important. Beside that you havent tell us your SR is for drift purpose or daily driving only.
iceinfire
28
503
drift & night drive for tea time .....
oven turbo ??? gt3076 izit abit bigger for me to hav super good respond ???
if i choose to get haltech than wat ll b the best but $$$ is around 3k for ecu oli ....
mines998
1,048
149
There thread about Owen turbo maybe you can try to find out or from web . For SR20 GT3076 still manageable beside that your current setup would allow you go for 500hp but if you quiker respond for sure GT28XX would be better. I would propose you use standalone ECU rather than piggyback.
AD_EG
6,328
231
Ipoh
nice thread. my brother just transplanted this into his volvo 240 GL..now time to poison him to read up on this.hehehe
mines998
1,048
149
This thread can't poison him much I think but you let him sit in your SR20 it better than a thousand words.
ryucky81
133
johore
hi bro,may i knw where ur bro did the conversion at JB n total hw much burn?
how the feel when driving volvo 240 wif sr20det? more than enough to pull?
me oso concider to put sr20det to my volvo 240 for daily driving.
thanks
Garrett
48
4
1,508
not adviceable for daily driving, s13 sort of manja compared to RB20/25, now spare parts at half cut shop oso difficult to get.....can say zero stock....example AR80 turbo. ecu, airflow meter n many more ....
for a 240gl weight to power ratio doesn't match...if 6 cylinder much better
---------- Post added at 12:26 AM ---------- 6 hour anti-bump limit - Previous post was at 12:14 AM ----------
my ecu syok2 'kong', so my car sleep at home for 2 months laaa...adoii..
---------- Post added at 12:28 AM ---------- 6 hour anti-bump limit - Previous post was at 12:26 AM ----------
not sure about SR20na but as for SR20det is a headache for me..
rakesh_v6
919
22
ur current modification would have reached 350, go for a dyno, wont cost u much
safc will do,
get a safc and go for dyno to get the HP n tune ur machine > sell it back haha, value still maintain for safc
A Post Every 5 Mins
Hi there,
I have been using my current suspension which is stock for the last 5 years, never changed since bought the car in 2001, anyway, the rear absorbers seem to be leaking now.
I have tested both the HWL and Titans, both are good but I'm just worried about the aftersales service, this I would go for Titans.
I have recently fully autofoamed my car which has improve chassis dramatically, for those who don't know what Autofoam is, it is to stiffen the chassis and...
