Need advice for sr20det !!!
chinwen09
Dec 6, 2010
11
yes, will get u around 350whp, go get nismo or tomei 740 injector, and a wastegate to make the boost more stable, actuator sucks...
iceinfire
28
503
Hks GT-RS izit same as Garrett GT2871r ??? Price same ???:bawling:
Any other super good respond turbine for my 350whp-400whp setup ???:banghead:
Haltech e6x / e8 & Microtech lt10 which is more suitable for me ???:smokin:
iceinfire
28
503
im driving 1 Nissan Bluebird U910 sss 1980 wit S13 sr20det....
jus wana to know which car CLUB can i join ? old skool ? nismo ? nissan ? bluebird ? sr20det ?:stupid:
chinwen09
Dec 6, 2010
11
Hks GT-RS is same as Garrett GT2871r, prize gtrs almost double the 2871r, 2871r around 4k, gtrs around 7k, but some said gtrs a bit better than 2871r, if you wan to go after respond, dont go turbo bigger than this, and you only can get 350 whp +- only, dun think can get near 400whp with this turbo with pump fuel...
chinwen09
Dec 6, 2010
11
for ecu go get the latest wan la, haltech sprint500 will do the job, but if your pocket deep go for haltech sport1000 lor, important is u need a good tuner to achieve your whp goal...
iceinfire
28
503
Haltech sprint500 enuf for my setup ?
I looking for standalone but $ not much ... Around 3k ... E6x / e8 / lt10 ???:banghead:
1 more question for all zth member ,
I'm driving 1 Nissan bluebird u910 SSS 1980 wit s13 sr20det,
Any car club can I join in zth ??? Old skool ? Nissan ? nismo ? Sr20det ? :love:
chromeibanez
87
1,508
haltech sprint 500 will do, with that budget. and more than enough with that setup unless you want features that is not supported
iceinfire
28
503
Planning to hav Garrett gt2871r & around 700cc injector so haltech sprint500 enuf for my setup to reach 350whp ??? Important question !!!
Temujin
1,474
619
Selangor
my previous sr20det uses 850cc injectors, walbro fuel pump, tomei fpr, garrett hybrid turbo, haltech e6x, tial wastegate, blitz intercooler, custom oil cooler, 1.5mm metal gasket and apex'i avcr..
boost was set at 1.2bar and i got around 330whp.
in my opinion the set up is good for more, but needs bigger turbo. forged internals is recommended too as 350whp is roughly around 400hp at crank.. some say 400hp is at the upper limit of the stock internals.
iceinfire
28
503
ENGINE-S13 SR20DET
MOD ON ENGINE- ENGLE CONROD
TOMEI 1.5 METAL HEAD GASKET
SUPERTECH VALVE SEAL
ACL CONROD & CRANK BEARING
WALBRO 255L FUEL PUMP
TOMEI ROCKER ARM STOPPER
ARP HEAD & MAIN STUD KITS
BRIAN CROWER VALVE RETAINER
BRIAN CROWER +1mm VALVE
BRIAN CROWER CAMSHAFT 264in & 272out + VALVE SPRING
ENGINE FULLY BALANCING
HEAD PORT & POLISH
CP 87mm PISTON
S15 TURBINE
3" DOWNPIPE
FRONT MOUNT VR4 SIZE INTERCOOLER
2.5" INTERCOOLER PIPING
3" EXHAUST SYSTEM
70mm THROTTLE BODY
TOMEI ADJUSTABLE CAM PULLEY
BANANA EXHAUST MANIFOLD
GREDDY INTAKE MANIFOLD
ORI S13 INJECTOR
SARD FUEL REGULATOR
APEXI AFC NEO
above is all my mod but haven dyno yet , so planning to get garrett GT2871r & around 700cc injector +++ haltech sprint 500 for the perfect dyno to shoot pretty result .....
so my important question is since $$$ not much izit haltech sprint 500 enuf for my mod to reach 350WHP ???:banghead:
A
An Unregistered User
Guest
My sr20det,full build internals with forgies,PowerFC,3071r dynoed at 396whp with dyno dynamics, boost 1.5bar
Ur setup pretty good.shud get above 350whp at 1.5bar boost.sprint 500 also can get the job done n its a cheaper option.u can discuss with ur tuner for more detail.
ehdrian
I Don't Care!
3,310
280
1,683
Penang
iceinfire: dyno ade with the new set up?..
A Post Every 5 Mins
Bosch, the century old household brand has recently introduced their latest range of engine oils, spanning fully synthetic, semi and mineral types with a host of viscosities.
Bosch Malaysia's 5-Star Workshop
I was privileged to...
