Satria Neo CPS Manual Gearbox
VectorX2
268
45
tried googling... no answer...
i planning to swap my gearbox to neo cps's gearbox... so i wanna do some research on it first...
i am driving saga BLM with 1.6 campro cps... the ori clutch is not doing well... can hardly find any clutch upgrade options for the ori aichi kikai gearbox.... going through the options i have to replace my gearbox or upgrade the clutch...
senbe84
115
If im not mistaken,all cps engine comes with 4.3 final drive gearbox.the housing of cps gbox code is the same with mivec ck housing.gearing is different.
ericmaxman
Senior Newbie
664
216
Ori or modded ni?
:hmmmm:
VectorX2
268
45
modded
anyway guys... solved the clutch problem...
one thing to take precaution to all manual BLM drivers...
me and my mech found out the so called ori clutch that he ordered... was actually not a BLM clutch... we suspect it was meant for nissan sunny 130y (b11)...
i bought an original clutch plate from proton itself... and its holding well now... even when CPS is activated...
note to all: BLM clutch has 4 springs and B11 clutch has 3 springs... so beware... it fits perfectly... but clutch slip is significant... even when using on a Campro IAFM 1.3
ericmaxman
Senior Newbie
664
216
modded
interested to see your ride bro.....hehehe
VectorX2
268
45
fast enough for a small car...max km did u achieve?
never tried... i seldom speed on a highway...
dun like the idea of driving a car with a map with uncertainties... the power output and AFR is just weird... so... planning to retune it... not because of power greedy... just wan things to be right thats all.. i happy enough with the power...
kambing69
216
33
nice ... well IMHO i think don't need that much of top speed, its how long to take you to the top speed, let say 200? enough already, we dint have many long roads in m'sia..
BTW yup CPS gear box come with 4.3 FD the gear ratio if im not mistaken was.
3.5 (somewhere around here, this is what i wrote base on my memory only)
1.9
1.4
1.1
0.7
FD 4.3
forgot the correct measurement~
VectorX2
268
45
not to mention alot of speed trap cameras.... haha...
if i am not wrong with my current aichi kikai gearbox... can reach a top speed of 180km/h at 6000 RPM before it stops going anymore...
speeding on straight roads not fun for me (except need to chase a plane...)
i usually utilise this mod when going uphill to genting highlands... haha... can smoke quite a number of cars...:biggrin:
The go-kart circuit at the Sepang International Circuit (SIC) was recently refurbished and has been relaunched together with a new operator in charge that will now co-manage the go-kart circuit with SIC.
Designed by renowned Formula One track designer Hermann Tilke, the man responsible for the layout of SIC’s main track as well as other tracks on the Formula One calendar, the go-kart track is 1.247km long...
