Stud removal tool and technique
sekut_kring
60
1,508
Dear All
i accidently broken a bolt during tighten my oil line from turbo to oil sump. the broken nut sunk inside and the bolt size is 10mm. Do anyone experience this and how to remove the stud/nut.::banghead:
Do i need to use special tool? the bolt size is quite small and difficult to drill the stud.
Can anyone suggest the 'stud removal tool' available on the market and where to get it?
or anyone have a good suggestion how to remove this stud.?
I try to remove it first and dont want to rethread to new thread size,ie. 12mm or larger.
Your idea/suggestion highly appreaciate and welcome.:biggrin:
Rgds
Z
'kesakitan di punggung' :nurse:
7,514
u'll need something like this
Irwin Spiral Screw Extractor Set, 5 Pc # 53535 by Irwin Tools
its simply a reverser drill bit...
can be used using tapping hand tools....
and got another version comes with fixed handle....
most major hardware stores got that screw remover.....direction of use also by drilling in reverse (as opposed to normal clockwise turning to tighten a screw)
jimmyae101
1,178
112
medan indonesia
yes,i know but no everyone know how to remove the broken nut inside oil sump tank...try my way,use ur finger turn it can?if cant,use screw drive and hammer pukul that nut secara lari 45; darjah...hope d nut can open by lawan jam...finally kalau tak boleh lagi,buka oil sump,u can buka nut dari dalam oil sump kaki panjang lagi kan ikut jam pakai player...confirm boleh buka punya...lagi tak boleh call saya...dengan bawa oil sump tu jumpa saya,saya tolong free
Milo33
185
i broke satria fender bolt before because of overtighten..
i go kedai ketuk..they put washer and weld it use the torch and succesfully take out the bolt..
about ur case not sure can use this or not..
sekut_kring
60
1,508
Thanks pomen_GTR for the useful info. Will try to find it at local hardware. Hope itcan extract small stud.
---------- Post added at 10:59 PM ---------- 6 hour anti-bump limit - Previous post was at 10:51 PM ----------
Jimmyea,
Thanks also to you for the reply. Maybe my note a bit confuse but the stud is outside the oil sump. It is actually sunk at oil return CHRA outlet to oil sump. THis happened during replacing my turbine unit. Kinda over torque during tightening process.
Anyways really appreciate your suggestion. It might help if my situation like that. Or maybe go straight see you to solve that problem. : ) :biggrin:
Rdgs
Z
sekut_kring
60
1,508
hi guy
This is where the stud is located. At CHRA unit. Notice the leaking cause i still drive my car even tighted with 1 nut.... so tempting to drive turbo maaa... :)
7,514
definately the tools i've suggested can be used :adore:
sekut_kring
60
1,508
finally task done on friday evening.
pic 1 - removal tool from hardware (rm 35)
pic 2 - dismantle exhaust cause drill cannot fit thro.
pic 3 - dill the stud .use smallest drill size. luckly the drill not broken...
pic 3 - Use removal tool and the stud finally out.. :biggrin:
pic 4 - broken stud
i would like to thank you all for your help and suggestion. Hope you will continuely give the support.
Rgds
7,514
good to know it works.... :driver:
A Post Every 5 Mins
The Ducati Club of Malaysia will be holding a gathering this weekend with the aim of setting a new record in the Malaysian Book of Records for most Ducati bikes ever gathered in an area. The event, held in conjunction with the Shell Advance Roadshow, will the club partner up with Next Bike, the sole distributor of Ducati bikes in the country...
