Gearbox 4g92p failing. HELP!
fadin_remorse
94
4
1,508
The gears are not engaging during cold start esp D,2,1. Takes 10 minutes before they warm up and work. Other than that the other gears are fine. Shifting of the other gears are also a bit more jerkier than before.
My options are
1.Overhaul the gearbox by a gearbox specialist (i am KL based) unknown of any good specialist.
2.Get a half cut Japanese 4g92 gearbox instead from a trust able source
Which option is cheaper/reliable? My engine has clocked in 181k
Thanks!:wavey:
change to manual :cost::rm2k (parts only not including installation) *
overhaul the GB :cost::rm800 (quality/warranty not sure 2place in kl i know u can send it)*
choose halfcut gb: cost::rm1.2k-rm1.6k (value varies if trade-in old GB or not)*
this is from my previous experience cost i also just replace my GB earlier this yer....my car clocking almost 200k km mileage now :adore:
xtremeleo
3,247
464
5,183
id rather overhaul the gb jer, at least u know u r gonna everything new inside there..
DanzEterna
15,911
3,371
www.primeperdanaclub.com
morning bro, thats completely out of my options gosh...... hows ur car?
tq bro. car is fine. the workshop already close down haha....
---------- Post added at 12:39 PM ---------- 6 hour anti-bump limit - Previous post was at 12:35 PM ----------
i agree wid u sir!! :biggrin:
fadin_remorse
94
4
1,508
yeah bro that was my main idea, just need a location for a trusted workshop around KL. Do you know of any?
---------- Post added at 12:52 PM ---------- 6 hour anti-bump limit - Previous post was at 12:51 PM ----------
Thanks for ur input bro still contemplating. Halfcut gb so exp meh?
---------- Post added at 12:54 PM ---------- 6 hour anti-bump limit - Previous post was at 12:52 PM ----------
See bro you agree what goes around comes around :driver: They deserved it
DanzEterna
15,911
3,371
fadin : u try to check out the thread 'car shops & services'
there are bout 2 shops that does gearbox overhauling.....
should be ok cos they are forumers here if anything goes wrong can shoot them later haha...
'IF' only k. if they done a good job then can praise them.
fadin_remorse
94
4
1,508
Thank you boss i will search it out, appreciate it :)
Shinjite
864
120
Klang
Better overhaul the GB
Peace of mind knowing all new parts will be in it instead of a used 1
---------- Post added at 04:10 PM ---------- 6 hour anti-bump limit - Previous post was at 04:10 PM ----------
fadin_remorse
94
4
1,508
yeah true bro checking up on that:driver:
kumar22mostwanted
1,562
152
HELL!!!
about the gear's not being able to engage at a cold start
im pretty sure that is a clutch pump issue as i also faced it not too long ago
about the car jerking when engaging gears i tink its a clucth prob
i would prefer overhaul coz its cheaper and more reliable
fadin_remorse
94
4
1,508
year bro kumar, do you know any gearbox specialists in kl area?
DanzEterna
15,911
3,371
u could try ag motorsports in pandan indah kl,
or seach for lan_eterna. he is a forumer here.
---------- Post added at 03:47 PM ---------- 6 hour anti-bump limit - Previous post was at 03:47 PM ----------
i modified my gearbox there as well.
Boss..wanna know if aircon receiver spoilt/the switch which control the rpm ( usually on top of the receiver ) spolt means what happen ???I've been having this problem recently and it's soo sickening.The rpm will be soo inconsistant and it effect the temp too.I brought it to a/con shop n that fella change the switch ( 2nd hand ..new one is pretty costly ).The next day the same problem happened.I'm feeling sick as the car is sooo inferior to drive !!Whenehev I stop ( eg traffic light ) the...
