Wiper Blades
silblade
Apr 13, 2011
13
14
503
CA-USA
Wiper blades are like squeegees. The arms of the wiper drag a thin rubber strip across the windshield to clear away the water.
When the blade is new, the rubber is clean and has no nicks or cracks. It wipes the water away without leaving streaks. When the wiper blades age, nicks or cracks form, road grime builds up on the edge and it doesn't make as tight a seal against the window, so it leaves streaks. Sometimes you can get a little extra life out of your wiper blade by wiping the edge with a cloth soaked in window cleaner until no more dirt comes off the blade.
Another key to streak-free operation is even pressure over the length of the rubber blades. Wiper blades are designed to attach in a single point in the middle, but a series of arms branch out from the middle like a tree, so the blade is actually connected in six to eight places. If ice or snow forms on these arms, it can make the distribution of pressure uneven, causing streaks under part of the blade. Some wiper manufacturers make a special winter blade with a rubber boot covering the arm assembly to keep snow and ice out.
Hi all. Which one is better? Normal multiple socket extension with individual switch or without swicth as below extension?
Usually abroad country use below one, without individual switch. One friend just came back from US said bottom extension is better.
