Why do JDM cars/engines have low mileage?
doppelganger
296
11
There are 3 main reasons for JDM cars/engines to have low mileage compared to here in Malaysia (i think :smokin:).
1. They reply mostly on public transportation.
2. Costs of driving a car in Japan are high.
3. They must pass a inspected called “Shaken” which determines if a car is still suitable to be driven on Japanese roads. As vehicles get older, maintaining them at the standards required by the shaken can become expensive. This is because beyond the tuner scene, most Japanese do not get involved in mechanical repairs, and as a result, mechanics can charge high prices. Vehicles which cannot pass inspection are not allowed to be driven on public roads. Unwanted vehicles must be destroyed and recycled, or as some do to make more profit, export the vehicle. As a result, many Japanese used vehicles are exported to other nations right before or after their Shaken is up.
Here is the low down on the Japanese car inspection called “Shaken”:
Reason for existence
The inspection system is in place to ensure cars on Japanese roads are properly maintained and are safe to be on the road. Another reason is to determine if a car has been illegally modified . Illegally modified vehicles and vehicles deemed unsafe by police will have a red sticker with the following: fuseikaizousha (不正改造車) (Illegal Vehicle) in yellow and the date the vehicle was declared not fit to be on the street.
Registration and Cost
Before a test can be administered on a vehicle the owner of the vehicle must call up a Shaken center and make an appointment by phone after which the owner must fill out paper work at the center. The cost for the Shaken is broken up as follows: 1,400 yen for paperwork and processing, 25,200 yen for the testing, 29,780 yen for 24 months of validity and 8,090 yen for “Recycling Department” with fees being added depending on the vehicle and its intended use (business, personal, commercial, etc.). These variables can result in a shaken costing from 100,000 to 150,000 yen (RM3,654.00 - RM5,481.00) or more. In comparison to the costs of the shaken a full diagnostic inspection of the very same Japanese models in Malaysia (via Puspakom) i think is just around a couple of hundred ringgit only. Right?
* Personal cars and 2 wheeled motorcycles have the first shaken last 3 years with every 2 years requiring a new shaken.
* Personal light trucks they must have a shaken done every 2 years.
* Personal trucks have the first shaken last 2 years with every year requiring a new shaken.
* Business cars require a shaken every year.
* Special vehicles require a shaken every 2 years.
Testing process
The process of the shaken is very simple and the following tests and steps are as follows for government inspection testing (however a licensed garage can also do this):
* 1: An exterior inspection to ensure the vehicle meets Japanese exterior regulations and does not have illegal exterior modifications (ie: extreme body kits).
* 2: A wheel alignment inspection to ensure the vehicle has its wheels in-line and can turn correctly.
* 3: A speedometer inspection to ensure the vehicle’s speedometer is accurate.
* 4: A headlight inspection to ensure that the vehicle’s headlights are correctly placed and aligned so as not to be in-line of other drivers’ sight.
* 5: A brake inspection to ensure the brakes work correctly.
* 6: An exhaust gas/muffler inspection which also includes looking at carbon monoxide and hydrocarbon output along with exhaust noise levels.
* 7: An undercarriage inspection which includes looking at suspension parts.
Should a car not meet any of the tests it will have to be repaired and retested before passing.
Requirements for tests
Exterior
* Tailpipes: Tailpipes are not allowed to protrude past the car’s body however tailpipes that are built into the side of the vehicle are allowed.
* Body kits/Aero parts: Aerodynamic mirrors, windage trays under the tail section of the car and body kits using front bumper scoops are allowed. However all aerodynamic parts must fit and be molded correctly so they are flush with the car’s body.
* Fenders and Overfenders: All fenders and overfenders (including widebody style-kits) must not inhibit the turning of the car’s wheels (which must be able to turn 30 degrees inward and 50 degrees outward).
* Spoilers: All spoilers (aftermarket or OEM) must not be wider than the car’s rear and must be bolted to the car’s trunk.
* Tail-lights: LED and traditional bulb tail-lights are allowed for all vehicles as well as European style fender turn-signals. However American style rear tail-lights and off-color turn-signals are not allowed.
* Windows: No tint can be present on driver and passenger side windows however commercial UV window blocker is allowed. Lexan windows are not allowed unless they are approved via a case by case basis. Stickers/banners on the front windshield and rear glass are not allowed. Etching on the windows, with the exception of VIN information, is not allowed.
Speedometer
The speedometer of the car will be tested by driving up on to a dynamometer. The vehicle will be propelled to 40 km/h twice and the vehicle’s engine rev amount will be recorded, should the vehicle have different numbers it will not pass.
Headlight
All headlights must be aligned to be in a straight line with their height on the car. Halogen, HID and bulb style head lights are allowed. All headlights must have the same color when turned on. Headlight swaps, making pop-up headlights into normal headlights, rally-car style multiple headlights and putting trim around headlights is allowed.
Exhaust/Muffler
Cars that are 10 years and newer must have carbon monoxide measurements of 1% and hydro-carbon output of 300ppm. Cars older than 10 years must have carbon monoxide measures of 4.5% and hydro-carbon output of 1200ppm. High flow catalytic converters are allowed however gutted ones are not. All O2 sensors must be in working order along with any oil catch tanks. Mufflers when tested for noise output will be tested at a 45 degree angle at a 50 cm distance. For vehicles 10 years and younger the max level allowed is 96 dB (decibels). For vehicles over 10 years of age the max level allowed is 103 dB.
Suspension
All bushings must not be broken or in bad condition. All control arms must be in working order. There can be no rust/corrosion on springs, struts or other suspension components. If the car has 4 wheel steering it must be working. The vehicle must also meet minimum height requirements which will be checked by referencing the lowest part of the vehicle (not including the suspension components). For vehicles with 200-249 cm wheelbase they must be 8 cm off the ground and vehicles with 250-299 cm wheelbase they must be 9 cm off the ground. For all other vehicles for every 50 cm over 299 cm in wheelbase add .5 cm to the minimum height and for vehicles under 200 cm in wheelbase subtract .5 cm to the minimum height.
Interior
General interior equipment must be still intact (ie: dash). Roll cages (must have padding around bars) and carpet removal are allowed. Bucket seats must measure 420 mm from left to right bank but can not be over 450 mm from left exterior side to right exterior side (total width of seat). Aftermarket seats made of fiber-reinforced plastic are not allowed. Any holes or rips in seats must either be taped up or repaired.
Workarounds
Many people create workarounds in order to have a vehicle that is otherwise illegal pass its “shaken”. Some of the typical workarounds are putting flanges in the exhaust that are mostly metal with a few holes drilled, airing up the tires more in order to gain height for the vehicle, putting ceramic pipe between the spring and the spring’s seat in order to raise vehicle height (this is commonly done on lowered coilover suspensions), reconnecting exhaust gas recirculation devices, removing injector connectors from the ECU (engine control unit), taping off parts of the headlight’s housing in order to make the headlights look correct, cleaning the underside of the vehicle to hide signs of oil leaks and trapping the speedometer so it registers the same numbers when tested on the dynamometer.
The Japanese tuner view of Shaken
Contrary to what is common amongst Western tuners towards vehicle regulations, many Japanese tuners respect the “shaken” and want to tune within its boundaries. In JDM Insider Volume 3: Kansai Adventure part 1 they visit a tuning shop called “Phonenix’s Power SPL” (a shop specializing in only legal modifications) and met with the owner who when interviewed talked about how the people who originally did modifications were the outlaws but since they made it legal to modify in Japan many professionals and regular people have started modifying their vehicles and have started to embrace the regulations set on cars so they can continue to enjoy their hobby legally.
End of Shaken period
Source: Hyperrev mags, Japan Insider mags, japs engines forums...
LuKa
618
19
Kedah
there are other factors aswell(other than its been tripped)........ some ppl dont drive their vehicle during winter.. coz need to change tyre for winter terrain.. car involve in accident is usually sold since workmanship for repairs is expensive
doppelganger
296
11
oh ok, thanks LuKa.:biggrin: its just that most of the cars i surveyed in grey import showrooms the cars there are more than 5 years old and/or have low milege. i was wondering why bcos their highways are like (some say better) than ours.:hmmmm: And also the fact that they can still export their cars (*note: Non-japs cars) to other countries is quite mind boggling.:adore:
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
some of the grey import "tempered" with the odometer.that's what i hear.
even those halfcut in m'sia do that so that they can sell it at a higher price.imo...
boyzone
2,669
38
5,148
dun look for the odometer if want to buy halfcut...
Btw, I have a fren at Japan, he said majority of the ppls and most of the time (99%) is using public transport.
Family car is just for weekend supermarket use ( to buy 1 week food in 1 shot )
sendai
555
Usually, they will use public transport to go to work..because company bear all the transportation cost and some company (mostly in or near the town area) prohibited their workers to drive to work..
yup,mostly use during weekend or holiday..and some sightseeing spots or attraction is better to use public transport..
dont forget about the congestion and the high toll..
The Marketplace Top Posts
Most modern engines are now electronically fuel injected and have plastic engine covers, this makes engine cleaning much easier compared to older engines with carburetors. I will show you how you can easily clean and shine a modern car's engine bay using only 2 Over-the-Counter (OTC) products.
This is a quick guide showing you how to quickly get your engine bay looking like new again. This guide is more suited towards modern cars' engine bays.
So here have have an engine bay that has never...
