Normally real sports car owner will not look at fuel and some other things. But since there is such criteria existed, here is the best choice:
Specification:
Engine
Engine capacity 1,332 cc
Engine type 4-cylinder in-line 16-valve DOHC
Compression ratio 10
Bore x Stroke (76 x 73.4) mm
Power 94 bhp
Torque 120 Nm
Performance
Acceleration 13s (0-100kmh)
Top speed 160kmh
Fuel consumption 16.6 km\L
Misc technical data
Transmission 5-speed (M)
Drive type FWD
Measurements
Body type Sedan
Dimensions (4257 x 1680 x 1502)mm
Wheelbase 2,465mm
Min turning radius 5,300mm
Kerb weight 1,035kg
Fuel tank capacity 40L
Brakes
Brakes (Front) Ventilated disc
Brakes (Rear) Drum
Suspension
Suspension (Front) MacPherson strut with coil spring and stabilizer bar
Suspension (Rear) Torsion beam with coil spring and absorber
