Where do you hide your sub-woofer
ektony
85
What a waste of space to install the sub-woofer in the Tiburon's boot. Has any one installed a compact active sub-woofer in the cabin area like under the seat ?
Pls share your success or your frustration. I am not getting the desired sound from my set. Like no soul in the music.
BlackSamurai
9,000 RPM
9,656
24
near 7-11
www.hcc.ne1.net
ektony, the position of sub-woofer will affect the total sound quality delivery. Get a better HU (Alpine CDA - 9855R for example) which you can adjust the delay of sub-woofer or amp. every second count. :biggrin:
of course, ICE workshop will able to recommend good stuff to you. :biggrin:
Tiburon, you here? maybe you can recommend something here.
dartango
204
wow..ektony..you are spending to spruce & spice up your coupe... will it be ready for us to view & listen?? :-)
scoupe
1,087
37
5,148
shah alam
my dad has a pair of sub woofer that are 6 by 9. supposed to be the first. its genesis brand, i would fit in the normal 6 by 9 speaker hole
ektony
85
dartango,
Nothing much to see and hear as I prefer to spend on maintenance. I just want to park my car in any available space and not to find a parking space within sight and sound . Therefore car is not shiny and nothing much to break in and steal !
Ace
715
Penang
anything that is less than 8" diameter of the sub would produce less disireable result.
Dear all,
I having a problem with my Turbo engine. Any body can give me some ideal thanks. Below is some info:
Spec
Engine E15ET Turbo (Pulsar EXA model)
AR48 Turbine boost setting 0.6bar (standard AR M10 turbine 0.5bar).
Blitz bov
No intercooler
Down piping (already remove the net)
2 1/2 inch piping from front to rear.
No center and straight flow at the muffler.
Oil pressure around 3.7bar (advice from Tong Turbo)
Problem
Engine RPM keep on fluctuated (hi n...
