What wrong, anyone have this problem before?
softmuffin
384
Need ur help here, My satria 1.6 4G92 Sohc 1st gear max can only go 20kmh or 25kmh where the RPM already at 5K or 6K. the same goes to my 2st gear, max can only go 30kmh or 35kmh. In english my 1st gear and 2gear cant tarik (no power) why?
If i push my 1st gear to 5K or 6K RPM, the car max can go is 25 sure below 30kmh when i tukar to 2st gear, the car will push back then only go forward, why.
I try my kelisa or my friends satria 1.3 or 1.5 dont have this kind of problem also where their can tarik more then 30kmh with 1st gear.
Can anyone tell me what's wrong.. I have change my clutch to exedy Clutch and clutch plate. still the same problem..
Please help
Thanks
muff
softmuffin
384
Whahahaha,
I just change my clutch last 2month (new exedy clutch and plate)
anywhere thx for replying ...
muff
simon
292
i think yr clutch is slipping......if only yr RPM goes high & yr speed is not increasing accordingly then definitely yr clutch is slipping.....when yr mechanic changed the clutch & clutch plate....did he check the oil seal which is between the gearbox & engine ??? if that oil seal is broken/bocor then there is a chance that the engine oil is slipping onto yr clutch & causing the "clutch slipping"...............this is my opinion....i dont know much but its worth to find out.....tq
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
Simon is right. Have it check fast...or it could be your clutch is not in full contact the friction surface.
