If not mistaken,worn out valve guide seal will only causes smoke at certain condition.
let the car idle for 2-3minutes and then rev the engine.if during idling there are no smoke and when u rev the engine only smoke are produced then its the guide seal.
Yours is magma engine.most probably u needs a top overhaul if the bottom part are in good shape.
for valve seal replacement now also certain workshop got special tools to replace valve seal without removing the cylinder head...so a very quick proccess around 3-4hours from start to finish...
I have just removed 3 pcs defective valve seals using my own special tool to removed retainer lock without removing cylinder head.
What the heck!!!! :top: that's what I call true DIY SIFU!!
Where'd you find the round part to compress the springs? Looks like a perfect fit!
