what is chassis/body strengthening?
audiolizard
89
1,508
i saw the thread topic of these things. what are body strenghten?
means old chassis like 15 years above cars the metals are become weak so go strenghten the chassis to make it solid back or what?
tankspeed
From Facebook
Dec 22, 2009
35
5
1,508
Yup. To prevent the chassis flexing and twisting about One is actual chassis strengthening by I think putting plates on body panels if im not wrong. The other is getting strut bar, lower arm bar, anti roll bar etc.
xbalance2002
1,501
349
1,683
yes reduce chassis flex but will it increase welding point more weak? as the chassis is very old
LittleWhiteWagon
1,656
187
P.J
Nope, welding is welding as long as it doesnt get rusty...
There are daaaamn many ways to strengthen your chassis! Depends on what car and how badly you need to strengthen it :biggrin:
audiolizard
89
1,508
so u mean like removing old panel and replace a new 1 into it or just add so metal plate to harden it? any moe specific details?
AD_EG
6,000 RPM
6,328
231
Ipoh
1 is by adding bars..at the front back and undercarriage...fenders...go to ultra racing website to see possible bars available.
another one is spot welding...they re-weld the welding points on your car..to strengthen it.
LittleWhiteWagon
1,656
187
P.J
Ill try and explain all yeah...
1. If the panel is SO rusted until theres a hole = Must replace the panel completely, take a piece of sheet metal and re-weld on. Usually this is very rare unless youre restoring some kind of classic car of some sort...
2. Spot welding. Imagine 1 piece of metal which is 3cm long, every 3cm they weld 2 pieces of metal together. So in between of the 3cm, that part can flex right? Spot welding welds in that middle part to make the 'flex area' smaller. Then after the spot welding the part that can flex is only 1.5cm etc. etc.
3. Bracing. Imagine your arm + a piece of metal bolted to it. Sure kuat right? :biggrin:
4. Chassis foaming. My own Nissan has been foamed, basically they just inject this foam thingy into the hollow sections of the cars chassis like the a-pillars (windscreen pillar) and so on. When it hardens it becomes like cement but light, so it strengthens it from the inside... Try imagine your hand being the car, and pretend your bones are hollow. The foam makes the INSIDE solid while the bracing makes the OUTSIDE stiff :biggrin:
And thats what chassis strengthening is! How you want to do it is totally up to you... :rolleyes:
audiolizard
89
1,508
hmm,i see, number 2nd i get it already thx, bout answer number 4, u mean they inject some thing like liquid all around the car and wait it dry to harden? i still dun understand la.. aiyo.:banghead:
93na
597
20
just wan to ask if like accident car wat can i do to help in the handling and strengthening as my car is old !!!!!!
LittleWhiteWagon
1,656
187
P.J
93na, your cars like mine :biggrin:
I kena langgar by a Jeep Cherokee (American monster!) which had the metal bullbar infront, I suggest autofoam!
Autofoam is like a foam when they inject into the hollow parts of the chassis, its liquid when injected but when it hardens, it becomes like cement. The best part of it is, it doesnt have ,much weight. 1 full car is around 2-3 kg tops...
The only downside is the price. Quite mahal when I did it but they charged me MPV pricing since my cars a wagon :rofl:
93na
597
20
bro how much it zit!!!! heard bout it!!!!! though of doin double stich like satria r3 not full but at some placs!!!!
tankspeed
From Facebook
Dec 22, 2009
35
5
1,508
Ive seen a R33 GT-R with the same foaming thing, pretty cool, keps the clean look without the roll-bars.
LittleWhiteWagon
1,656
187
P.J
Its not welding u know... Its a foam :biggrin:
http://www.autofoam.com.my/autofoam/
Check out their website, it cost around RM2K++ for my car because it has extra window pillars... For normal sedan + hatchback should be 1k+ only :rolleyes:
http://www.autofoam.com.my/autofoam/index.php?option=com_content&view=article&id=23&Itemid=73
These are where you can foam. I went for the track one since its already so expensive and im going to do this 1 off, might as well get my moneys worth haha.
Darth Evillus
69
4
8
33
After the penang bridge news
I think I need to do something like this d. Scary news
Anyway any good place in Penang or klang Valley?
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
Chassis bars price is very much std with most shop.
This is just my personal opinion based on that freak accident;
1.public road is not meant for racing.
2.Everyday car is not meant to be driven like in the incident.
Even with complete bars and good rubbers it wont guarantee anything. Your car will handle better but there are just too many other variable at play on public road with not much margin for error.
  • Like
Reactions: Izso
guys, it would be most useful to me if you guys could recommend me a place around KL that I provide good chroming service. I would like to rechrome and restore my old 1970s Toyota KE bumper back to its former glory.....
BTW, would the the chroming service help me repair small-small dents, surface pittings too? before chroming is done?
I don't mind paying more as long as the final product is satsifying...
thanks! :_:
